19-06-2006, 08:48 PM | #1 | ||
Mr Forty Seven
Welcome to the on going saga that is my ELXR front conversion.
Ok, first after spending money restoring the wrong bonnet, I buy a bonnet from Ford which has the XR vent holes already pre-cut into them, I'm pretty sure it's an EF bonnet as all the part numbers have EF in it. When I go to fit the sequential scoop in the hole, firstly it doesn't quite fit properly and secondly there are small gaps between the actual scoop and the hole, less than 1cm but still very noticeable. Now, either the scoop wasn't made correctly or I'm thinking EF vents differ slightly in size and shape compared to EL ones because the scoop was designed to replace an ELXR vent. Does anyone know if that is true? Regards, Michael
EFII Fairmont Ghia Fully Optioned In White XR Kit, Engine & Springs. Leather & Sunroof Also Featuring NFERNO Registration Plates ELXR Front Bar & Bonnet with Sequential Scoop 18x8 Graphite Rims, Genie Extractors and Exhaust, Chrome Moulds ELGT Steering Wheel, Clear Repeators, Cornering Lamps, Tinted Windows Walnut Highlights, Pionner DEH-P9650MP Headunit & Pro-Series Speakers Local Playground: Brisbane CBD and surrounding suburbs |
19-06-2006, 08:53 PM | #2 | ||
Bring on the lion...
Dude that sucks. Im not 100% sure, but i think the EL and EF vents are the same shape, so the holes in the bonnet should be the same as well, as people sometimes replace the EF vents with the EL vents.
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD 9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile XC Falcon project car underway...... |
19-06-2006, 10:07 PM | #3 | ||
The scoops arent always made well. Mine isnt quite the right shape. I was furious at first, but yeah, you get that with cheapish custom stuff :(
Heritage Green EL Ghia Black AUII XR8 Ute |
19-06-2006, 11:18 PM | #4 | |||
Mr Forty Seven
20-06-2006, 05:22 PM | #5 | ||
SO how much are these scoops worth? ANd where are they bought from?
