View Poll Results: Which would be the Quickest | |||
Stroker it and here that V8 Scream | 22 | 38.60% | |
Supercharge it and Listen to the Whistle | 35 | 61.40% | |
Voters: 57. You may not vote on this poll |
23-06-2006, 06:25 PM | #1 | ||
hey guys i need to know which would be the best for my EF XR8
what i have: EF XR8 II, 5 Speed, Short shift, Pacemakers and full exhaust system. the question is should i stroke it (347) which includes me doing maf, t/b, gt40p's, cam and the stroker kit would be around 11.1:1 compression or supercharge it 10psi side mount vortech blower p-trim, GT40p's, cam , maf, t/b, 550cc injectors and which would i need a EMS for? Im after the lowest 1/4 times NOT looking for my d!ck is bigger than yours power figure |
23-06-2006, 06:27 PM | #2 | ||
Last warning
stroker would be more legal
blower would be quicker
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
23-06-2006, 06:32 PM | #3 | ||
windsor user
stroker plus blower would be nuts
i see it like this... stroker if your engine needs a rebuild......... or blower if your engine is tip top...:P |
23-06-2006, 06:42 PM | #4 | ||
The one and only
Everyone knows my option and it's not even listed!!!
If i had to pick one, I'd pick stroked.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
23-06-2006, 06:47 PM | #5 | ||
Slide Baby Slide
Stroked and blown.
I'd go stroked to start with. Mmmm....stroked, blown and gassed! now thats an idea! hehehehehe
:the_finge You want more inches...........STROKE IT!!! :the_finge Mr Super Skid-Man |
23-06-2006, 09:12 PM | #6 | ||
ur all sick in the head and turbo is not an option LTDHO lol i know what u were thinking
its done 132,000kms so which one?????????? |
23-06-2006, 09:14 PM | #7 | |||
23-06-2006, 09:19 PM | #8 | |||
23-06-2006, 09:24 PM | #9 | ||
Id go the second option.. sounds more fun
23-06-2006, 11:17 PM | #10 | |||
24-06-2006, 02:25 PM | #11 | ||
Oops, I slipped....
Supercharger would be quicker with the setups you listed, but a lot more expensive.
GT40P's aren't -that- good in the grand scheme of Windsor heads.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
24-06-2006, 09:54 PM | #12 | ||
Boost it!!!!
Then after a couple of years when your motor is getting a bit tired you have an excuse for a stroker rebuild Boost is best! |
24-06-2006, 11:25 PM | #13 | ||
SnortPerformance.com
Am I the only one to note that 11.1 is NOT a good compresion ratio for boost?
Why are people suggesting stroking and supercharging, that makes no sense at all! BlueXr8, I say boost it. Which ever way you go, I'd suggest that you use an aftermarket EMS with either option. |
24-06-2006, 11:27 PM | #14 | |||
windsor user
for what reason do you say stroking and blower isnt a good combo.......seems to work juuuuust fine on LTDHO's car |
24-06-2006, 11:42 PM | #15 | ||
Well BlueXr8 said that the stroker kit had a compresion ratio of 11.1:1 which would be great for an N/A car but obviously not for boost. So, if the comp. ratio of the stroker kit is 11.1 then stroking it and boosting it is not a good idea. Get my drift?
By the way, I have no idea about LTDHO's car, so I'll make no comment on it. |
24-06-2006, 11:45 PM | #16 | ||
windsor user
well, of course if you were only going na then that comp ratio would be what you're chasing,
people werent suggesting to go blown and stroker with a comp ratio of 11.1... oh and as for LTDHO, i suggest you have a look here http://dannyshosting.com/gallery/ltdho?page=1 Last edited by LUXO_8; 25-06-2006 at 12:01 AM. |
25-06-2006, 01:12 AM | #17 | ||
BT you can vary the compression ratio of the motor by choosing different pistons - if he built the stroker with boost in mind down the line he could have, say, a 9:1 comp ratio and still make heaps of power N/A, then thow a few Psi in later on and have a complete weapon.
Obviously CR determines how much total boost he can run, but for a street car you want to keep it fairly high to retain off-boost efficiency. |
26-06-2006, 06:50 PM | #18 | ||
ORSM FORD CRUSIERS
BLOWN !!!!!!!!!!!! sound Oh so good!!
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
27-06-2006, 12:22 PM | #19 | ||
[EBGLT]
mmmmmmmmmmmmmm Supercharger!!!!!!!!!!!!!!!!!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
27-06-2006, 01:05 PM | #20 | ||
Dont CAPA make ADR approved S/C kits for the Windsor? I'd supercharge it, that way you retain good driveability and probably better fuel economy under normal driving conditions than stroking it.
27-06-2006, 10:30 PM | #21 | ||
The 'Stihl' Man
Nothing better than a V8 with a decent exhaust and supercharger peroid IMO!
I love the whiiiiiiine. Plus its a manual, it sounds better changing through the gears than an Auto, stupid little thing but I hate the lag/shift noise Autos make.
28-06-2006, 08:10 PM | #22 | |||
28-06-2006, 08:16 PM | #23 | ||
Giddy up.
Supercharge it and then when the engine gives up the boot from the blower pull it down and stroke it, lol.
28-06-2006, 08:49 PM | #24 | |||||
own the road
T3 TE50 #146 Quote:
