Old 21-09-2006, 09:59 PM   #1
REDAUXR6II
REDAUXR6II's Avatar
Default Ride height
If I put a set of 18 inch rims on my XR6 that has the standard 16 inch rims will it look like a tractor?
I ask because I wont be able to afford superlows for a few months.
It should sit the same height shouldn't it if the overall diameter of the wheel\tyre is the same?
REDAUXR6II is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2006, 10:14 PM   #2
HLC
Audi S3
youll find that the tires wont squash down the same amount, so it will sit a little higher. nothing unbearable though.
Old 21-09-2006, 11:48 PM   #3
AU3 HERROD XR8
XR8 M8
AU3 HERROD XR8's Avatar
mate i reckon your better of just waiting for the super lows for the next few months and put the rims on with the super lows all at once, you also have the advantage that both the superlows and the 18" rims you want price will drop a little aswell
The King of the jungle doesn't whistle.. he roars!
AU3 HERROD XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2006, 11:59 PM   #4
ronwest
All Bran = Regular Member
I put 17's on my Ghia and it now sits 21mm lower than the standard 16's (ie the 17's are 21mm smaller in diameter than the 16's)
If you know your current and new tyre sizes, you can work out your diameters here:- http://www.tyremaster.com.au/fitment_tips/diam_calc.htm
edit: actually, the car sits 10.5mm lower
Old 22-09-2006, 03:51 AM   #5
blackers10
blackers10's Avatar
it should sit about the same
it all comes down to tire and rim combo..
look in my thread in the workshop section
rolling on 20s at stock height.. and had 18s for a while there too..
now its on superlows and looks pimp
good luck
Old 22-09-2006, 08:33 AM   #6
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
good luck
Blackers is right , the car should sit around the same height with the correct legal rim & tyre combo.
The bigger the Rim , the lower the profile tyre, to keep the rolling distance the same on the wheel as specified. Tyres with the same rolling distance roughly are gonna be the same height no matter what profile the tyre is.
(bigger the rim , lower the profile tyre... etc) .
Cheers.
eg.
:eclipsee_
