24-09-2006, 05:12 PM | #1 | ||
Its Resonating!
Anyone know the dimensions or product that would fit into the airbox, Ive done a search but cant really find anything thanks....
24-09-2006, 05:15 PM | #2 | ||
Depends on which airbox you mean
24-09-2006, 05:18 PM | #3 | |||
Burnin Rubber
Standard flat filters seem to flow relly well in AU's as it is, I would leave it as that.
2001 AUII Forte (LPG) K&N Air Filter Tickford Air Intake ***Coming Soon: Clear Side Repeaters*** Quote:
24-09-2006, 05:20 PM | #4 | |||
Its Resonating!
24-09-2006, 05:20 PM | #5 | |||
Its Resonating!
24-09-2006, 05:21 PM | #6 | ||
I have put i think it was 11 inch in mine, just fit. Pain in the **** to do but. Better to just get 8 inch one. Fits better
24-09-2006, 05:28 PM | #7 | |||
Back on the road
How is the air going to get into the "biggest pod filter that will fit" if there is no space left around it in the airbox... ;)
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
24-09-2006, 05:31 PM | #8 | ||
There is pleanty of room, its 11 inch long not wide so it has room. It also helps if you have a hole at the front of the airbox to get some more air from behind the headlight
24-09-2006, 05:32 PM | #9 | |||
Its Resonating!
Being resonable about the size ofcourse, I know wat u mean though, no good blocking the flow with a huge pod : |
24-09-2006, 05:37 PM | #10 | ||
So den go with the 8 inch one. Most people have those ones
24-09-2006, 05:45 PM | #11 | ||
Then. A den is where lions live.
Pod in a box is a waste. It's actually no different (on my car, anyway), to having a flat panel K&N. Ther BA Pod setup, on the other hand, is well worth it, and the ultimate is the G&D airbox or similar. For an AU, you need the biggest filter you can fit - I believe G&D use a 4" opening, and the filter is around 10" long.
24-09-2006, 05:48 PM | #12 | ||
Its Resonating!
I was looking at getting one of these if I wasnt going to get a pod, they look awesome. But the price....
http://www.bmcairfilter.com/infoCDA.asp |
24-09-2006, 05:53 PM | #13 | |||
The one I have is: Code : CDA85-150 Price (US $): 258.35 D1 (mm) D2 (mm) L1 (mm) 85 150 200 CARBON DYNAMIC AIRBOX SUGGESTED OVER 1.600 CC
24-09-2006, 05:57 PM | #14 | |||
Its Resonating!
24-09-2006, 06:00 PM | #15 | |||
24-09-2006, 06:02 PM | #16 | |||
Its Resonating!
24-09-2006, 06:07 PM | #17 | ||
I had it on the XR8, and when I went LPG, I was advised to go back to standard airbox due to the need to fit a balance pipe for the gas. I have since replaced that with the BA setup, as it allows proper fitment of the balance pipe, while retaining a Pod filter.
I did have the CDA on the Forte for a while as well, but replaced that with the standard airbox (and now BA pod) when I was chasing up an intermittent miss (set everything I could back to stock). Turns out the miss was coilpack, not air intake related, so the CDA has just been sitting around in the box. I keep meaning to throw it on ebay.
24-09-2006, 09:47 PM | #18 | ||
As JC said, a pod in the standard box is a waste. Been there, done that, lost power. If you want to keep the std airbox then a flat panel filter is the way to go. If you feel you MUST get a pod and stick it in the box, get a foam filter (finerfilter make great ones). That will give you the best compromise (and probably a hp or 2 more).
