Old 15-10-2006, 03:03 PM   #1
BLSTIC
Default Burnout Car - VK (Shock/Horror)
Ok so my stepdad bought a VK commodore for $40 for the sole purpose of using the radiator, and he is only keeping it as a spare, which means that he really doesnt care much about the rest of the car.
So I reckon I can get the use of it as a burnout car.
The question is how to modify it to make it into a skid car.
Currently the car has a black 202 (with extra blowby), a 350 holley, a tri-matic auto, and no brake master cylinder.
Unfortunately due to the copious amounts of blowby, the engine will probably make more smoke than the tyres, and will need to be repaired/replaced. We have a red 202 (tri-matic as well) and extractors to suit a HQ style engine bay, so that will most likely make its way in.
The exhaust will be a simple side dump from the extractors, and I will find a way to put the holley on the red motor. The master cylinder will be replaced (albeit with no rear brakes connected), and of course the diff will be locked.
Does anyone have any other ideas as to what else I could do?
oh yeah, and any cheap ideas that relate to more power will also be accepted.
cya
Ben
BLSTIC is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 03:29 PM   #2
xxxc
tuff
xxxc's Avatar
why bother
.......................FG XR6 UTE...........................
......................xc fairmont gxl.........................
...................GQ coil cab UTE ..........................
xxxc is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 03:40 PM   #3
BLSTIC
well, me liking tyre smoke so much, I am likely to do a skid no matter what. And doing a two-wheel burnout in a cheap car, legally on a proper burnout pad beats the **** out of doing a single-wheeler on the street, and getting fined after I break my diff and can't drive away.
that and it gives me something to do with my spare time.
Old 15-10-2006, 03:52 PM   #4
70caprigt3k
Nitrous Junkie
70caprigt3k's Avatar
Go for it, as you said its better to do it in another car legally and it wont matter if it breaks. It may be a bit rich for the purpose but a manual conversion may aid your tyre shredding ability.
'97 Toyota Supra - 6spd, Tilton Triple Plate, Built 2J, T88H-38GK, HKS 272 Cams, Haltech E11V2
70caprigt3k is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 04:34 PM   #5
old_mate
Smash the Boost
old_mate's Avatar
ditch rear brakes. drop in the new motor with a decentish cooling system. Ditch the exhaust (if they allow it)
otherwise, find a not too stuffed 253/308 and drop that in
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 04:53 PM   #6
TUF_302
The Vengeful One
TUF_302's Avatar
Originally Posted by DUMPT
why bother
Why not if you can do it cheaply.
TUF_302 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 04:54 PM   #7
dansedgli
dansedgli's Avatar
Get a V8 for like $300 out of the trading post, spool the diff. Big radiator as mentioned.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 05:16 PM   #8
LUXO_8
windsor user
V8 auto, no rear brakes, dual exhaust exiting into rear wheel wells to help pump out the smoke(it works)
should be a balltearer
Old 15-10-2006, 05:39 PM   #9
EF_Frmnt
EF_Frmnt's Avatar
i agree with the exhaust into wheel wells... and big radiator an a pair of thermos. and engine fan if you put front mounted thermos
Oh and if your sneaky put two windscreen washer jets facing just in front of the rear tyres in the wheel arches an hook up some lines to get the wheels spinning constantly no matter how sticky the pad (dont admit to it though)
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 07:32 PM   #10
castek
lol, sounds similar to my project. although the vk i got my hands on is a efi. so far i've put bigger injectors, disconnected back brakes, fitted engine and trans oil coolers. spins so easily. going to make an exhaust at work using a 2 1/2 pipe.
good luck and have fun.
castek is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 07:34 PM   #11
LUXO_8
windsor user
another thing i forgot to mention...it has to be LOUD to get the crowd excited, especially if its a V8.....theres nothing worse than a dead quiet car trying to rip a burnout....all you hear is tyre squeel
no muflers...at least twin 2.5" straight exhaust out into the wheel wells......
Old 15-10-2006, 08:07 PM   #12
Walkinshaw
Two > One
Walkinshaw's Avatar
its probably mentiond above (cant be bothered reading)
V8
Auto
Twin exhaust (aim at rear tyres)
MASSIVE radiator
no rear brakes
Spooled diff
have fun
Old 16-10-2006, 05:33 PM   #13
BLSTIC
yeah, we have a spare 308 to suit a HQ-style engine bay backed by a TH-400. Its seized though. maybe a week of diesel down the pots will fix that.
then I will need a tailshaft though too, as a traumatic backed six isnt likely to be the same length as a turbo back V8...
yeah, exhaust will be minimal. I was thinking of the rear wheel jets. anyone know of a suitable fluid?
cya
Ben
Old 16-10-2006, 06:05 PM   #14
kyro_02
V8 wannaabeee
kyro_02's Avatar
get a mini spool for it :P
kyro_02 is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 06:24 PM   #15
LUXO_8
windsor user
save ya bickies and just weld it..... not like its gonna be a streeter
Old 16-10-2006, 06:44 PM   #16
Skooter
Skooter's Avatar
you could just use water from the washer tank but what works really well is bleach go and rub some between your fingers right now, and you will notice how much traction breaking power it really has.
Skooter is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 07:19 PM   #17
BLSTIC
yeah, i also have this really powerful degreaser that you can't rinse off your hands properly, maybe it would be good.
Old 16-10-2006, 07:24 PM   #18
BLSTIC
is there anything out there that is slippery and evaporates really quick?
Old 16-10-2006, 08:18 PM   #19
AMT
Come fly with P.S.I...
AMT's Avatar
Fuel + Match = Burnout car........or should i say burntout car...... :
FG Turbo ute..lowered,20's Turbosmart Bov,Plazmaman piping,Flash tune coming...
AMT is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 10:42 PM   #20
maz1300
maz1300's Avatar
not a good idea to weld the diff!!! as it will crack....
get some lead (heaps) melt it in a pot over the bbq and when hot poor it into your spider gear housing on the gears etc......once its cooled down you will have a very strong locked diff and it costed sweet **** all ;) plus its real hard to break ....
maz1300 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2006, 05:09 PM   #21
BLSTIC
the way I weld diffs is to remove the spider gears (the ones not attached to the axle), and weld the gears that are on the axle to the housing nice and solid. none have broken yet (plenty of axles in FWD cars though). Most people just weld all the spider gears together with whatever tacking they can get connecting them to the housing...
but I like the lead idea. know what kind of shops would let me have diff-full of lead for next to nothing?
cya
Ben
Old 17-10-2006, 05:24 PM   #22
woodsy109
My cousin had a vn burnout car and used the windscreen washer bottle to spray water onto the radiator. Made heaps of difference to how long the car could be on the rev limiter
You could also use the washer to squirt water on the back wheels. I'm not sure about using other liquids like detergent. I don't think the burnout people like you using anything other than water.
woodsy109 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2006, 05:27 PM   #23
woodsy109
Also if you plan on having a passenger all the time, wire the temp guage and a button for him/her to control the radiator sprays. Leaves you to concentrate on the circle work.
Old 17-10-2006, 08:00 PM   #24
BLSTIC
yeah... or I could just hook it up to a temperature switch. I think they can be had pretty cheap. Ill have a look now.
and have a button for the rear tyres... I cant have that on all the time.
