16-10-2006, 12:54 PM | #1 | ||
The 'Stihl' Man
Just wondering if there is any point in doing my cam before I do the exhaust?
Eventually I will get around to both, but I want one of these done before the Geelong Dyno Day; I have to have some kind of engine mod.: I wanted to do the cam first, but will having the stock exhuast system hamper it? So therefore there is not much point. And if the cam is the go, what type should I get for the EL, remembering that it has the XR6 cam now. How many people get good results with wades? I want the idle to remain normal aswell. :nutsycuck If the exhaust is better off going on first, I think Ill just play it safe and get some pacy and redback combo as they seem to do the job. Cheers
16-10-2006, 01:02 PM | #2 | ||
You win again, gravity!!!
I would say that the exhaust would be best to do first. As the cam will only work to its best potential when combined with an exhaust, intake and other mods...
Whats stopping you from doing both?? A cam regrind and shims aren't expensive, and if you are tight for money, do the cam + a cat-back system... that way you can have both, and get the pacy's later on
1966 Fairlane 500 XL
16-10-2006, 01:07 PM | #3 | ||
The 'Stihl' Man
I might get there, or I mightn't, well see. I just moved house and Im at uni so untill holidays Im only working weekends.
I was under the impression that a cat back did sqwat all, and compliments the headers.
16-10-2006, 01:07 PM | #4 | |||
exhaust first is what i say |
16-10-2006, 01:10 PM | #5 | |||
The car was marganily quicker with the cat back, but the biggest difference was the way the car reved under load... so much more responsive.
16-10-2006, 01:15 PM | #6 | ||
The one and only
Do exhaust including headers first.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
16-10-2006, 01:15 PM | #7 | ||
Exhaust first.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
16-10-2006, 01:21 PM | #8 | ||
I got my exhaust first, noticed a slight difference, got a cam after that (no extractors still) and noticed a fairly big difference and the exhaust note changed alot too. If I was to do it again i'd do the same thing.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
16-10-2006, 02:43 PM | #9 | ||
EBII XR6
i was thinking of getting a cam too but i only have a 2.5" cat back exhaust. so by what iv read will it be ok to put a bigger cam in. also if i do that do i need any computer extras or valves or anything like that, or can i just put the actual cam in and thats it??
DEVLXR
16-10-2006, 02:46 PM | #10 | ||
Depends on what cam you get, my wade 1004 was fine without any computer mods, you can just put the cam in (with shims if it's a regrind). Most off the shelf cams won't need computer mods so you should be right.
16-10-2006, 02:49 PM | #11 | ||
EBII XR6
cool. wheres the best place to get these type of things? id have no idea! what are shims too by the way?
DEVLXR
16-10-2006, 03:03 PM | #12 | |||
http://www.fordforums.com.au/showthread.php?t=68884
16-10-2006, 03:12 PM | #13 | ||
EBII XR6
cheers man!
DEVLXR
16-10-2006, 03:13 PM | #14 | ||
do you have to have head work?
iv just got a EB XR6 with pacies does this mean the wade 1636 is best? how much would it cost - "$120 change over"? + shims? Damon
EBII XR6 5 spd
>>MY CAR!!<< Pacemakers, 2 1/2 Sports Exhaust, Thermos, XH Snorkel, KnN Panel Filter, Custom Black Interior, 18x8 Speedy Graphites with King Super Lows.. and more mods to come! JVC Touch Screen Head Unit, Front - Pioneer 220w 6" splits, Back - Pioneer 220w 6" (all amped), Pioneer 12" 1000w sub, Powered by Pioneer 800w Mono Amp 127.51rwkw |
16-10-2006, 03:17 PM | #15 | |||
A grind (If you are a fordmods member) costs around $120, they charge about $100 for a set of shims (You can get them from ford for way less apparently) Then as an option you have have a vernier gear so you can dial the cam in. I think we need a sticky explaining cam choices and installation lol :P
16-10-2006, 05:26 PM | #16 | ||
Tuned @ Pitlane Frankston
Extractors ain't an engine mod polyal. It's an exhaust mod.
Do whatever you like first. Best bet is to free up the exhaust first though.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
16-10-2006, 06:49 PM | #17 | ||
exhaust FTW!
