Old 14-12-2006, 02:08 PM   #1
infusion
Default Fuel Consumption EF!
hey again guys
as many of you may know i bought a EF manual with 110,000kms about 2 weeks ago and since then welded the pedal box and put a stereo in..
next problem is my fuel consumption and idleing.... :evil3:
my car always seems to be running on 5 cylinders when idling.. it seems to be ok when driving but when u stop moving it will continue on 6 cylinders for about 5 secs then drop it down to 5... :( any ideas?
also another thing is my fuel consumption.. when i bought it it had about 1/4 in it and until i filled it up i avgered 12-13 on the trip computer. after filling it up i reset the trip computer.
since then it has been sitting around 20.. ive done about 200kms and im now down to 1/4 tank.. WTF?!?
any ideas guys it would be appreciated..
i hope this problem isnt going to be costly :(
cheers
infusion is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 03:17 PM   #2
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
how hard do you put your foot down is the first question but you may have a head gasket problem, look at your oil and see if its milky,
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 03:29 PM   #3
infusion
ive driven it moderatly.. few squirts here and there...
no..oil is not milky..
Old 14-12-2006, 03:34 PM   #4
DNKPWR
DNKPWR's Avatar
change or renew spark plugs, leads first...
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
DNKPWR is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 03:40 PM   #5
infusion
would i be better off just taking it into ford rather than trying to pin point the problem myself?
Old 14-12-2006, 03:41 PM   #6
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
give it a full service, like everything,
diff oil
engin oil
oil filter
new airfilter or new K&N or recherge
fuel filter
sparkplugs
leads
put 98 octane in her and it will drive like new if not u got a bigger issue
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 14-12-2006, 03:54 PM   #7
DNKPWR
DNKPWR's Avatar
Does it have a problem with reving out?? if so could be a blocked Cat or exhaust
Old 14-12-2006, 04:18 PM   #8
infusion
naa it can red line no problems..
Old 14-12-2006, 04:18 PM   #9
infusion
what about the isc, throttle body or oxygen sensors, or thermostat are they common.. or related to my problem?
Edit: i would like to mention..
say im doing 60kms/h and take it out of gear and let it coast the car will idle on 6 cylinders until it come to a stop.. wierd?? :S
Old 14-12-2006, 06:49 PM   #10
crannersEL
crannersEL's Avatar
Had the same problem in my EL, was sitting around the 18-20ltr/100k mark, i changed the following.....
1. spark plugs and leads
2. o2 sensor
3. Temp sensor
Also did a head gasket shortly after, which may have caused a high than normal fuel eco....
Hope that helps :-)
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 08:24 PM   #11
335JET
@jas_23_
335JET's Avatar
i reckon its your oxygen sensor for your bad fuel economy.
335JET is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2006, 03:42 PM   #12
Gohan
i get round 12.2km to 100km with some high mileage on the clock thought i dont run my car under 1/4 tank due to the fuel pump is in tank
Gohan is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2006, 04:21 PM   #13
VS MANUAL
i reckon your idle issue would be dirty idle control valve.
In commos it can carbon up and block air getting through causing rough idle.
If your moving, there is a speed sensor that tells the car to idle higher ( i think it allows easier gear changes) and the idle valve is open more. When you stop, the idle drops becaus ethe idle valve closers slightly.
Give it a clean and see.
As i said, it works usually for commodores, i assume ford have the similar set up.
Economy issue. Try the stuff as mentioned in previuos posts.
VX SS - 6 SPEED - MAF TUNE - TWIN 2.5 INCH EXHAUST
VS MANUAL is offline   Reply With Quote Multi-Quote with this Post
