The Maltese Falcon
ok this might seem like a stupid question, but it's one i don't know the answere to.
Do ford australia measure the power on their vehicals from the flywheel or rear wheels? |
Last warning
flywheel.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
Purveyor of filth
As EF said, the figures quoted when talking about the power figures are flywheel. The power figure is an average of a sample of engines they put on the dyno.
and then it becomes confusing as Holden use a different typre of measurement when it comes to kW ratings as well ... compared to Ford.
DALLY 41
why cant we just all get along on the dyno and make the readings from the wheels... who cares if the numbers dont sound as big still its a more acurate reading
#6 | |||
With da Warlords
Dyno's can be a long way out between 1 and the other. Whereas the avg of 10 engines on a bench gives a preety good indication of power & torque output Another thing to think about is, to dyno a car the engine must be in, & you would get 2 different reading between a manual and automatic, even using the same engine.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
The Maltese Falcon
ah cheers fellors so any1 know wat the series one forte's were? from the rear wheels? guessing it would be the same as far back as the ef because i dont think it changed?
#8 | |||
Audi S3
it you are talking about AU series one forte's, then 157kw at the flywheel
which works out to about what HLC has in his signature ... it can vary between 110-120 rwkw though ... depends on the tune of the vehicle and how well it has been looked after. Also the auto can give a slightly lower reading than the manual due to stall converter robbing a few kw.
