Old 04-12-2006, 10:31 PM   #1
csv8
csv8's Avatar
Question Where's The Pollen Filter ??
My Fez is coming up to its 30k service. It says to change the pollen filter .
Cann't find it ? Where is it ?
Thanks
csv8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2006, 06:18 PM   #2
Imolator
Quad Cam
Imolator's Avatar
Its behind the centre console. if you look in the passenger footwell there are a couple of screws to remove a part of the upper section near the heater core. The pollen filter then just slides out and you slide the new one right in.
Imolator is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 11:19 AM   #3
csv8
csv8's Avatar
Not on mine, mustn't be fitted to the LX model. Cheers
Old 07-12-2006, 12:25 PM   #4
Imolator
Quad Cam
Imolator's Avatar
Maybe I wasnt too clear with first description. If your car has air con then you've got one. You must remove the front part of the consol. 1 screw and some clips at the rear, then there are 4 torx scews to remove the cover for the pollen filter, then it slides right out and you slide the new one right in.
Old 09-12-2006, 11:03 PM   #5
csv8
csv8's Avatar
Ok , I have aircon, so, will let FORD do it. Don't have torx drivers.
