14-12-2006, 11:00 PM | #631 | ||
Last warning
tyres still scrubbing?
did it clear the driveway with the front bar on? :P
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
14-12-2006, 11:02 PM | #632 | |||
Mr. Multiple Projects
1985 KB laser Turbo white lightning 3 door EFI 1927 Model T 1998 GU Patrol 2004 Forester Turbo 2006 Corolla Wagon BLAAAAAAACK |
14-12-2006, 11:08 PM | #633 | |||
E-Series Owners Club
It definitely doesn't clear the driveway well!! :P lol |
14-12-2006, 11:30 PM | #634 | ||
Last warning
Hahahah.. was always gunna be the issue.
looks like the planks will be the go.
15-12-2006, 12:08 AM | #635 | ||
The Goodz' PR Manager
Goddamn that car looks hot.
That's a huge PITA that that had to happen, I hope its all sorted out soon buddy. You too Nhoj!! Knowing your car though it'll just fix itself again =P
It's GREEN!
15-12-2006, 01:48 AM | #636 | ||
EBII XR6
OMFG that looks psycho in that pic! i think my heart skipped a few beats when i saw that pic! no bl00dy wonder it grabbed attention at the servo and when you drove past the holden boys! god damn!
DEVLXR
15-12-2006, 02:17 AM | #637 | |||
Does Steve have a car?
Was talking to a few people about my rattling problems and they don't think it's bottom end related. Hard to explain what it sounds like but they suggested it could be something to do with the starter. It rattles badly for a split second on startup and the sound does seem to come from the bellhousing area, which led me to origionally believe it was something to do with the torque converter or flywheel. Since that's all been changed and the rattling is still there, i suppose the starter is the only other thing that hasn't been looked into. Crossing my fingers on this one
AKA Mr Silver Chasing reliability....: "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
15-12-2006, 02:27 AM | #638 | |||
We couldn't believe the amount of show offs when we were on that particular stretch of road. We had one guy in a turbo BA fishying past us up the hill and then came back for another round. A fair few holdens sporting P'plates felt they had something to prove, but with my hood open i'm sure they knew who was boss ;) There was also one VT that lives around the corner of my street sporting a hood scoop, holden sticker across the windsheild, and a budget quad cold air induction was also in the lineup. Thing is when my cars running these types are no-were to be seen. Typical :/
15-12-2006, 11:05 AM | #639 | ||
EBII XR6
oooh yeah of course they know whos boss! especially when they can see an intercooler and chrome piper covering the engine bay! i dont want to scare you but lets pray to god that know f***h**d will decide to key your car, if it were me (and you'll most likely be doing the same!) i wouldnt be leaving it know where by itself!
DEVLXR
15-12-2006, 03:29 PM | #640 | ||
**** i want it!!! As others have said, looks nuts in that 3rd pic.
15-12-2006, 03:29 PM | #641 | |||
Was thinking last night that i may check if the flywheel has any play in it. If for some stupid reason the bolts are loosening then it's one more thing that may be causing the rattling sound. Makes sense to me, as when the clutch is pushed in, the spigot bearing is pushing against the diaphram, which would stop any play in the flywheel. I know that when we origionally pulled the auto out, the bolts could be undone by hand, so maybe we didn't torque it up enough and the same thing has happened :/
15-12-2006, 04:30 PM | #642 | |||
Tuned @ Pitlane Frankston
Did you locktite the flywheel bolts? I wouldn't bet on a loose flywheel though. I mean, you and John aren't 5 speed experts. When you put that one in, neither of you knew how to drive a frikken stick shift! The rattling could be a loose flywheel. Did you put a little bearing in the crank? It's called a spiggot bearing. It doesn't get pushed against the diaphram, the thrust bearing gets puched against the fins on the pressure plate, which disengages the clutch. The thrust bearing doesn't spin around..
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
15-12-2006, 05:04 PM | #643 | ||
That EA just caused an upwelling of Little Daves <tm>
15-12-2006, 05:33 PM | #644 | |||
16-12-2006, 03:30 PM | #645 | ||
OK, i think i may know what the problem is. Was talking to turbo tony last night and he had the same symptoms on his car when he installed his brass button clutch. Seems that because the clutch plate is thinner, it causes a slight freeplay in the clutch fork. If that is the problem, it will be easily fixed by attaching a spring to the clutch fork so as to elminate the slight freeplay. It makes sense as the sound dissapears when you push the clutch pedal in, and also the sound is at lower RPM were the engine will be vibrating more agressively. If he had the same problem with his brass button clutch then i cant see why mine wouldn't do the same thing.
16-12-2006, 06:16 PM | #646 | ||
Shoot.
Did you clip the thrust bearing into the clutch fork?
20V Turbo |
16-12-2006, 07:31 PM | #647 | |||
We tested the car today and seems if you go above about 1200-1300rpm the rattle stops. Now for some reason my car likes to change it's idle patterns, and will hover from anywere between 800 and 1300rpm. Yesterday the car was idling at about 1300rpm, and only a slight rattle was heard. This would have been the clutch fork rattle which would stop as soon as we pushed the clutch in. Tested the car today and it was idling a little lower, but the rattles were much much louder, and woudn't go away even with the clutch pushed in. I hate my life....
16-12-2006, 07:41 PM | #648 | ||
do you have the little spacer plate that goes between the allen bolt and bellhousing on the fork
17-12-2006, 10:41 AM | #649 | ||
rofl copter
steve, sounds to me like flywheel bolts, onto the crank. mine was doing the same, would stop rattling above 1500~ but anywere below sorted sounded like a REALLY loose baffle or somthing tapping somthing else. take the inspection plate off and try and move your flywheel.
GQ patrol.
.... thats all |
17-12-2006, 04:52 PM | #650 | |||
If it is the flywheel bolts, i will be asking myself why they came loose in the first place. I know that the first time they came loose it was due to me being a bit rev happy, but we really haven't been giving it much at all (apart from that day Dave came over, and the problem was already present at that time). The bolts were definately tightened and loctited, so there is no chance that it was a case of installation error. What i noticed was that ever since we first got the engine running, i would rev it in nuetral to about 3000-4000rpm, and as the revs dropped the whole car felt very shaky. Now if my flywheel bolts are loose, i'm led to believe that there may be a problem with something else that caused the engine to shake the bolts loose. If that's the case, i will probably look at replacing the bottom end. Either way, i wont be checking anything till after new years. I really can't be bothered dealing with this car and would rather just enjoy my holidays without having this problem running through my head :/
17-12-2006, 05:31 PM | #651 | ||
V8 Turbo Hoon
i think if your flywheel was loose you would have more noises than you are describing. I would not drive the car in fear of my legs being cut clean off.
17-12-2006, 05:45 PM | #652 | ||
i have had my torque converter bots fall out on me. when it was running on one bolt it only made a little clunking noise in low rpm only. it also has a rattle as if you hold a piece of steel and rattle it side to side between 2 pieces of metal about 100mm apart.
i would definately get it looked at, as it if falls apart you will be kicking yourself for the fixing cost. or buy my T5 as a spare
17-12-2006, 06:48 PM | #653 | |||
17-12-2006, 08:45 PM | #654 | ||
Last warning
thread closed by request.
