Old 13-01-2007, 09:51 AM   #1
GK
Walking with God
GK's Avatar
Default Dash Squeak Elimination?
Whilst perusing the Nulon site for info I posted before about Throttle Body cleaning, I came across this other product in the Nulon range. It's said to eliminate dash squeaks!
"Automotive Uses:
Nulon Ezi-Glide is excellent for lubricating door, bonnet and boot hinges and catches, as well as electric sunroof mechanisms and seat runners. A simple spray allows car windows to slide up and down easily – without staining black window rubbers. It eliminates squeaks in car dashboards and door seals. It also protects and beautifies door seal rubbers."
Hmmmmm very interesting.
Anyone tried it? I might get some I reckon!
http://www.nulon.com.au/products.php?productId=ezi330
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 13-01-2007, 09:54 AM   #2
BlackLS
Posts: n/a
Sounds like silicon lubricant... The hardest bit of fixing dash squeaks is locating them first.
Old 13-01-2007, 09:55 AM   #3
GK
Walking with God
GK's Avatar
Quite true! LOL!
GK
Now gone!
On LPG
Old 13-01-2007, 10:00 AM   #4
bonk182
BonK182
I don't think it is a silicon based lubricant. Selleys have their version of ezi-glide and its a powdered lubricant - though not like graphite which is dark in colour and is messy. It comes in a green bottle and is kinda cool - We use it for lubricating the runners on the docking saw at bunnings. Give it a go - i think you'll find the selleys version is pretty good stuff.
(not so sure bout dash sqeaks though) heh
James
bonk182 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 10:04 AM   #5
cArSiK
chances are the squeek will be coming from the pastic strip at the rear on the dash where is meets the windscreen. In my AU i took it out (2 screws and afew clips) and covered the contacting faces it in sticky felt and it stop making noise......maby give that a go.
James
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 10:15 AM   #6
private9
www.TUFFCARPARTS.com
private9's Avatar
James
That's a great idea covering that bit in felt!
In my EF, I had a heap of dash squeaks and groans - I took off that section of the dash and tightened all of the bolts that secure the dash to the firewall - every single one was loose! No more squeaks now and about 10 minutes of work! I know it's not an AU, but the concept is the same!
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 12:10 PM   #7
mattp
mattp's Avatar
That's the stuff I use to lubricate my windows, it's silicon lubricant. Good stuff.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 01:34 PM   #8
Dauphin
Irregular member
Dauphin's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Endless work keeping the AU.com.au web site happening
James
Can you please explain a little about what's involved in removing for us dummies? Thanks.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny
My hovercraft is full of eels!
Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971).
Dauphin is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 01:46 PM   #9
cArSiK
you need a small phillips head screw driver (stubby one is good) and locate the two screws that are on either side of the panel.
Undo the screws and remove them so they dont fall down the windscreen air vent.
Gently prise the panel up with a flat head screwdriver at one end until it unclips from the dash, continue unclipping the panel moving towards the other side of the car.
Once the panel and rubber strip that attatches to it is out, cut the sticky back felt (from spotlight, $2.50 per sheet - you will probably need two sheets) and apply it to the underside of the panel that you removed and also the part that contacts the windscreen.
James
Old 13-01-2007, 07:20 PM   #10
GK
Walking with God
GK's Avatar
James
Good idea James, will give it a go methinks!
GK
Now gone!
On LPG
Old 13-01-2007, 08:55 PM   #11
HLC
Audi S3
James
i thought that squeak was just myplastic p-plate wedged between the plastic and the windscreen. maybe its that.
oh well, thats going into the 'too hard' basket :P
HLC is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 11:36 PM   #12
hilly1981
**** the only annoying noise I get from my AU is the door lock rattling, so I just push it down so it locks whilst driving and the rattling goes away!
Problem solved lol!
1998 AU Falcon Forte (Galaxy Blue, Sedan, 2.5" Lukey cat-back sports exhaust - single muffler, 17" ROH Wheels, 235/45/17 tyres, Low Suspension, Rear Spoiler, XR6T Intake Snorkel, K&N Panel Filter)
hilly1981 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 03:09 AM   #13
blackers10
blackers10's Avatar
hilly just wrap some electrical tape around the door lock thing and it wont do it anymore!! it gets a little tighter for a few days till it moulds it self to shape
mine was rattling with the stereo till i did this
you just grip it and pull upward to pull it out. the manual says to use multigrips and some cloth to stop it from scratching/marking it
ill have to give the panel felting a go for sure!!
On The Street Feature Winner Performance Ford Mag
See my car at:-www.aufalcon.com/blackers10
blackers10 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 09:11 AM   #14
cArSiK
Windows Down, Music Up should do the trick HLC....
All you guys are going to be drivien mad by these noises now that your thinking about them
Old 14-01-2007, 06:33 PM   #15
GK
Walking with God
GK's Avatar
You're probably right about that one! LOL!
GK
Now gone!
On LPG
Old 14-01-2007, 08:55 PM   #16
HLC
Audi S3
they are always down and the metal is always loud how dare you suggest otherwise!:
