14-01-2007, 01:49 AM | #1 | ||
Hey All,
My car has again back fired on gas and has put a rip in the rubber elbow that joins the throttle body from the airbox, this is the 2nd time it's happend and im wondering maybe i should just replace it with a BA airbox or justget a pod filter and stick it at the end of the pipe that goes into the airbox.... Any ideas on how i can go about doing this? And also any thoughts on my ideas? Other then that the car is running like a dream!!!! Cheers Simon |
14-01-2007, 02:07 AM | #2 | ||
I've had 3 backfires in mine with the BA XR8 Pod style airbox and 3" metal intake pipe and had no problems at all (except one guy who nearly had a heart attack at Bunnings when one of the backfires happened).
If you have a balance pipe, i don't think it will work effectively with a Pod, but might be worth a go. But you should be able to get a BA Pod airbox for under $100 and then you just need to replace/fix the pipe between the airbox and TB - metal is better for backfires, but runs fairly hot.
14-01-2007, 02:18 AM | #3 | ||
Right out sideways
my mates dad has an EF on gas, and he was on holidays, and the sucker backfired like yours did, but he said it was alot louder than other backfires hes had with it, popped the bonnet and it melted all intake pipes and set the air filter on fire !!!!
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
14-01-2007, 07:41 AM | #4 | ||
Blown 5L coming
first thing i would be doing is eliminating the backfire, replace plugs, leads and check ur air filter to make sure it isnt overly blocked. with the leads, check to make sure there is no cross firing (white residue on leads at points where leads touch eachother or the motor) and if plugs are replaced every 20-30,000ks this should minimise risk of backfire and blowing ur airbox and ducting to pieces.best option with a pod filter is to keep it in the airbox so as to retain ur balance tube. but if u remove the snorkle and airbox so the pod filter isnt recieving "forced" air to it, u wont need the balance tube.
14-01-2007, 10:01 AM | #5 | ||
Resident Nyctophobic!!
do you have the rigid clips on teh airbox or the egas springs?
Orbits secret to life: Eat less, move more! |
14-01-2007, 11:49 AM | #6 | ||
FG F6 310, AU2 XR8
taxis in wa run a ocky strap around the air box , no clips or gas springs.
peeler hub of AUXRATE |
15-01-2007, 01:27 PM | #7 | |||
But it did have the egas springs on it! Cheers Simon |
15-01-2007, 01:43 PM | #8 | ||
Adapt or perish...
Hmmm... I've had the ute do a LPG backfire on me once in the two years of having it and it's only made the springs loose. I have an EF airbox with 3" metal pipe joined to the elbow.
Carless
15-01-2007, 04:10 PM | #9 | ||
they call me Tibbo
On the rubber elbow, leave the hose clamp closest to the airbox off.. If it backfires it will simply pop off and damage nothing
15-01-2007, 05:13 PM | #10 | ||
Professional Mouse Jockey
Funny, Ive never had a backfire on any of my LPG cars over 8 years and 3 cars (not incl the BA which is sequential).
Is it an 8? cause if it is leaving anything unclamped after the air flow sensor could cause problems with the air fuel ratio because of air leaks. If its a 6 then never mind (they dont have air flow sensors do they? Ive never owned a 6 later than a EA but the Im pretty sure efs dont. They rely on the TPS and MAP)
Isuzu MUX for towing horses - currently no Fords in the stable Time flies like an arrow; fruit flies like a banana. Groucho Marx
15-01-2007, 05:27 PM | #11 | ||
FTF Car Club NSW
had an old EF taxi that was on gas as my first car, backfired once so bad it actually split the brake booster diaphram - resulting in no brake "boosting", didnt realise this had happened though until id pulled out of the parking spot and then couldnt brake when a car stopped in front of me! luckily quick reaction time and reefed the hand brake on - had to drive home 10k's in traffic using the handbrake to slow down and stop ing_sm
15-01-2007, 05:42 PM | #12 | |||
Will this be ok? Cheers Simon Thanks for the replys everyone! You've helped : |
15-01-2007, 05:49 PM | #13 | |||
Adapt or perish...
Carless
15-01-2007, 05:57 PM | #14 | |||
Roughly how much would the piping cost??? : Cheers Simon |
15-01-2007, 06:12 PM | #15 | ||
mine backfires about once month, seems to do it when i accelarate from lights after a trip along the freeway. i have the spring clips and have had no probs, just open bonnet redo clips and off i go.
15-01-2007, 06:13 PM | #16 | ||
Full length from TB to where the airbox is would be around $150 to $180, plus HPC coating if you want to keep it coolish. If you get a bit just from the elbow to the TB, I'd say around $60 to $90 as it only needs the slightest bend in it - though if you're going a Pod, then really it wouldn't need a bend at all.
