Hi ,
Got a bit of a problem with tring to program the remote on my AU II XR6 The car was a finance company repo and as such had no remotes...just onekey, So after buying another remote from a wrecker i tried the procedure to program it but to no evail, after inserting the key and turning it to acc, pressing the rear demist button 3 times or more in less than five seconds....nothing happens...no door locks cycling ....nothing !! What the hell do i do now????? roh |
you must press it exactly 3 times, with the door closed, so on, off, on, then the door locks should cycle, then you can continue
OK...job done ..thanks..i think the problem was i was doing it with the door closed but not locked !!
thanks again... roh |
Well mine took a few more goes to get mine to work.
Just keep trying, dont press it to fast, try 5 times (thats what mine took) you'll know when it has started receiving mode as the doors lock. Good Luck
:eclipsee_ MY CAR :eclipsee_
15+ Years!
Glad I found this thread.
My car didn't acknowledge it had gone into learning mode. I tried the new remote by chance and it worked. Go figure. Rubbing my belly while patting my head and hopping on one foot must have worked after all!
AUII Fairmont Ghia Sedan Sparkling Burgandy Work in progress ![]() https://photos.app.goo.gl/7roViz57bb2Stkzx6 |
