After breakin the upper cable was broken from the slider that lifts the window.
I will replace the slider,but, the problem is the motor does not appear to work. Are there any sensors in the motor or tricks to get the motor and cables in the correct position to work again?. How can I test the motor? Thanks for any advise Last edited by phantom; 11-04-2005 at 11:32 PM. Reason: additional information |
Two > One
Replace the entire unit (bracket, cables, motor, regulator) in one hit. Shouldnt be more than $70 from a wrecker for the entire unit
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
