Old 31-01-2007, 08:30 PM   #1
mk1gt500
Default au xr8 cruise control
I have got problems with my cruise i have replaced the brake light globes and put a new brake switch on the pedal but still does not work. The buttons on the wheel work when you go to set the cruise with the button on the dash it jumps to set and then will go back to the on sign. Does any body know to fix this please.
thanks : :
mk1gt500 is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2007, 08:31 PM   #2
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Did you Replace them with LED Lights ....
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2007, 09:58 PM   #3
mk1gt500
No replaced with standard light globes 21/5w
Old 31-01-2007, 10:12 PM   #4
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Check your Fuses , and Check all your Lights are sitting in the Cups Properly
AU2PWR
Old 01-02-2007, 07:43 AM   #5
mk1gt500
I have checked all fuses and the lights still will not work what next???
Old 01-02-2007, 08:39 AM   #6
JefXR8
JefXR8's Avatar
was thinking about doing this,does it cause problems?
JefXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2007, 09:07 AM   #7
SSVPom
Formally FairmontPom
Are you sure it's not the fuse? Tiny blue 15A thing...
SSVPom is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2007, 09:24 AM   #8
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Led's Sometimes cause the Cruise Control not to work as they always have a current running through them , so the ECU thinks the Brakes are on Permanantly , Brakes = No Cruise Control ,
Its Gotta be either the 15A Fuse or the Globe is Faulty ,
AU2PWR
Old 02-02-2007, 11:23 PM   #9
Tech Trainer
Are you sure about that?
Tech Trainer's Avatar
Is the car manual or auto?
If manual check the clutch pedal height.
Tech Trainer is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2007, 06:45 PM   #10
mk1gt500
The car is auto can it be anything other than the fuse or the lights ??
Old 03-02-2007, 07:02 PM   #11
AUXRVIII
Have a look at the pressure switch on the brake master cyl for leaking fluid, disconnect the switch and inspect it, the fluid shorts the switch which stops the cruise from setting.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2007, 08:33 PM   #12
mk1gt500
Is the switch open or closed type at the moment it is closed eg power runing thought it
Old 03-02-2007, 09:18 PM   #13
AUXRVIII
I've actually never tested one, but I've replaced plenty due to leakage of fluid into the connetor.
Old 03-02-2007, 09:22 PM   #14
AUXRVIII
Just checked, brake pressure switch is normally closed.
Old 03-02-2007, 09:24 PM   #15
AUXRVIII
Try testing the resistance of the switch
Old 03-02-2007, 09:25 PM   #16
mk1gt500
When you take the plug off the switch there is no fluid in the plug.
Old 03-02-2007, 09:26 PM   #17
AUXRVIII
PM me you email & I'll send you some info.
Old 05-02-2007, 12:32 AM   #18
Gonz
BA XR6T UTE - ANIM4L
Gonz's Avatar
sorry to jump in with my own problem, but...
hmmmm, funny you should mention this, ive recently fitted LED parker/brake light and have since noticed my cruise control doesnt work when i have my head lights on...works fine with the headlights off!! i was thinking it had something to do with it, kindy thinking along the lines of when you use LED's on your blinkers, it makes them flash faster!
with the blinkers im told you need to fit an in line resister(i think)to trick the system for it to operate normaly, is this what i need to do to the brake lights??
Gonz.
BA XR6T"ANIM4L" UTE UNDER CONSTRUCTION!
WA Member of proUTES.com : we need more FORDS!!
CHECK OUT MY OLD AU UTES!! IN HERE!
CHECK OUT MY OLD FG UTE!! IN HERE!!
CHECK OUT MY LATEST BA UTE!! IN HERE!!
YOUTUBE POWERCRUISE VIDEO!! CLICK HERE!!
YOUTUBE INCAR VIDEO!!CLICK HERE!!
Gonz is offline   Reply With Quote Multi-Quote with this Post
