14-02-2007, 06:27 PM | #1 | ||
Tickford Rocket
Hi guys, i had to register again as i changed isp and then forgot my password. DOH
Question for you all, my series 3 sprint as the space in the parcel shelf for a 8" sub, it also has a stereo cable hanging there too. I'm assuming its a factory cable as its in the factory harness with the fomoco stickers on it and it has a black plug on the end. I'd like to hook up a small base sub, but is this live??? I've ohm tested it and get nothing, unlike the other rear speaker cable which all read active. I'm not much of a stereo type of person but like my tunes. Any one know what this cable is for?? and can it be used for a sub??? and is it as simple as plugging one in. Xrocket. |
14-02-2007, 07:49 PM | #2 | |||
All Bran = Regular Member
It may be the subby cable but you'll get nothing without an amp driving it. Tha amp (if fitted) is located in space behind the carpeted panel at the drivers side rear. If no amp but the cabling is there you may be able to buy an 8" sub and amp from the wreckers. Then all you have to worry about is *if* the wiring is connected to the head unit... |
14-02-2007, 08:57 PM | #3 | ||
DJR TM#54
Yes it for the sub, but you need to hook it up to a amp.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains |
15-02-2007, 12:22 AM | #4 | ||
Brembo Lover
I have a full premium sound setup out of a Series One fairlane if you are interested. I have upgraded to Alpine gear and this stuff is just sitting here. Im not sure if the wiring is the same, but it shouldnt be too hard to figure out.
Mine: 2007 BFII XR6 Turbo in Conquer with Sunroof, BFII Typhoon rims, CarPC, FPV Leather Wheel Hers: 2006 BF Super Pursuit in Vixen |
