Old 06-04-2007, 07:54 PM   #31
b2tf
not here much anymore
b2tf's Avatar
Originally Posted by BLUPRNT XR8
Will tell you in about 3 weeks time, you see I've recently purchased the whole system, MSD DIS4 HO Ignition module, msd coil packs, msd tach drivers, msd leads and msd billet 130 amp alternator/bracket set. G&D will be doing the install so will definately be able to see if it does make a differance after a re-tune then dyno run.
Austin I have a mate who is in the automotive industry but didn't realise the contacts he has :Up_to_som
Mick
Ahhh I see, so he doesnt work at Ricerbarn like I do :hihi:
Be very interested to see how you go with all of that, my alt is a bit on the crappy side of things.
2024 F150 XLT
Old 08-04-2007, 02:39 AM   #32
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
Mick- can you change that HO ignition for the standard one, do it if you can.
I'm having issues with the HO one getting very, very hot and being particularly hard on ignition components....... If you can't make sure you can keep it cool- a fan or a/c tube to it if inside the cab (where I'd suggest- and make sure you have a fire extinguisher)
Also I did some resistance tests on the Top Gun, Eagle and MSD leads (I have them all) and the MSD's were way way way out in front. 5% of the Top Guns and 7.5% of the Eagles (2840 vs 1922 vs 145 ohms from memory in that order). The Eagles looked nice and had the protective heat boots but the MSD's are way way better............
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2018 Ford Ranger RAPTOR
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2007, 09:56 PM   #33
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
Noticed on Ebay MSD coils for sale to suit the Au,will keep an eye on them
New Owner of a fiesta ST
5 FTR 5 is offline   Reply With Quote Multi-Quote with this Post
