Old 21-04-2007, 11:34 AM   #1
clackerz
Default Injector Install
Hi,
I have just replaced the head gasket on my 5lt EB Ghia, although when i installed the injectors i dont think ive installed correctly as when cranked, fuel over flows past the injector o-rings and sits on the intake manifold. My question is, when injector is fitted should the top o-ring be visible, i think maybe i have not pushed the injector hard enough into it's recess.
Any help would be great here, thanks.
Justin
clackerz is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2007, 11:59 AM   #2
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
You might need to replace all the O-rings, it's not hard to rip one when you're taking them out. You can see the O-ring with the injector installed. I'll try to get a pic later today.
For future reference, you don't need to remove the injectors to remove the manifold, just unclip the fuel rails from the fuel lines and leave the rails/injectors installed on the manifold.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2007, 12:43 PM   #3
mcflux
mcflux's Avatar
Clackerz, they should all "pop/click" in with a significant "drop" (ie move 5mm inwards upon popping/clicking in). I don't remember whether the o-rings should be visible or not sorry.
Old 21-04-2007, 12:50 PM   #4
LUXO_8
windsor user
o rings shouldnt be visible, you havent put them in far enough....
the o rings seal against the "cups" on the fuel rail, so they need to be up inside it and down inside the manifold......
