ok so i tried that mod a long time ago but never tried cutting the box to bits to make it fit perfectly...today i took it out and took pictures.
now can anyone whos done this 'cutting' please tell me where to cut....the redish stain on the box is where its rubbed against my engine bay paint.....im guessing that where i cut but any help please tell me.. oh and how did you patch the hole?...is that plastic able to be heated and remolded or is it thermosetting plastic. i have almost every angle of the box if you need more. hopefully this should also help anyone wanting to do this later on, or abit worried about it fitting. ![]() EDIT: looking now i dont think the ruler will help at all, the box is on an angle oh well treat it as coordinates
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
#2 | |||
Spin 'em Habib !
AU2PWR |
#3 | |||
Get the hair dryer out, heat the areas where the red paint is and use a piece of timber to reshape it.
#5 | |||
Walking with God
GK
#6 | |||
though i dont know whether that plastic will just get hot and eventually burn or heat and become soft enough to remold.....it is in an engine bay remember
Spin 'em Habib !
its thermoset , wont budge with heat ..
AU2PWR |
#8 | |||
The plastic needs to be much hotter than the heat an engine bay radiates thats why it's not affected. |
Spin 'em Habib !
heating something thermosetted will de-strengthen it . becomes brittle , learnt this working for a Plastics Moulder .. The Heat needs to be concentrated in a Small Area , Heat Gun or Hair dryer is too big
AU2PWR |
Yep I can accept that, but reworking the bottom of an airbox by heating it isn,t going to adversly affect anything or result in failure of the box.
Spin 'em Habib !
Cool , so when the Engine Bay heats to its usuall 80 degree ambient temp and your stress heated airboxs cracks when its Cooled and Heated about 5 times , you can come back and say .. Bugger i Should of listend to the Fat Red Haired Kid ...
AU2PWR |
#12 | |||
Back to Le Frenchy
Daniel is right, it will crack and I'd say you'll be lucky to even get 5 cycles of heat and cool out of it. Just remember too it may only be the bottom that cracks but it is more than likely that the lid will come free and then you'll have unfiltered air entering your engine.
#13 | ||
I made the suggestion becuase I have heated the parts of the airbox where the spring type clips are fitted for LPG, the top is always in place after backfire, clips also remain in place after backfire, when Tickford used to fit the LPG systems they did a similar thing, if the mod can survive a backfire then I can't see a problem with this.
#14 | ||
Spin 'em Habib !
Totally Different Situation , the backfire is 3% Heat , 95% Pressure and 2% LPG , Hence the Air Not Escaping the Intake Quick , pressurising and blowing the top off the Airbox ,..
Heating it will cause it to loose its strength and then crumble later on , so when the car Does Backfire on the good old BBQ Gas , bits of Airbox go into the Throttle Body and .. Well you know the rest .. Now here is something i could help with When i had a stab at this before just cutting mine , the BA/BF Lid Just Missed fittin on teh AU Bottom , try and fix this Riddle .. and you will have one better than me .. But Heating it is a no no .. Cheers Daniel
AU2PWR |
#15 | ||
I think you need to have another read of my post. I heated the airbox where the clips are fitted. This acording to you weakens the airbox. Now if the box can survive backfires, how is an unstressed part of a lower box going to fail?
#16 | ||
Miami Pilot
![]() Join Date: Jan 2005
Just get a BA XR8 pod and be done with it. Apart from a small piece of adapter silicon hose (2.5" to 3" joiner will work), it fits like a bought/made one. Ever wondered why the BA XRs didn't come with the square box, and why BA owners upgrade to the Pod filter setup (and the Pod owners upgrade to G&D). Just save all those hops, skips & jumps and buy a G&D/Bluepower box, or the value alternative, the XR8 Pod (it's all you need for the I6).
#17 | |||
#18 | ||
FTF Club Moderator
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
#19 | ||
i have moded my AU box with an extra 3" pipe at the front i plastic welded it and it looks and performs well I just used a short PVC fitting from bunnings cut to suit I then used black vinyl spray to make it look the part
#20 | ||
looks sweet, did you notice performance gains
#21 | ||
with the other mods yes and sounds better too also got KN filter Tickford snorkel and Hyclone(don't cringe I tested and on petrol it gives 60 to 80 Ks extra on a tank not as much on lpg but stiil there are gains) advance extractors 2.5" redback system now I love driving through maccas drive through the echo is awesome.
#22 | |||||
Back to Le Frenchy
#23 | |||
Miami Pilot
#24 | |||
Only last Friday I serviced an 279000km EF with factory lpg which had the airbox spring clips secured by heating the box still had all of the clips in place. The rest of the intake tubing had plenty of tape covering splits and breakages. Last edited by AUXRVIII; 29-04-2007 at 12:20 AM. |
#25 | |||
www.TUFFCARPARTS.com
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
#26 | |||
Miami Pilot
Talking of BA bits in other cars, I just re-engineered and fitted a fully functioning BA shifter handle (auto) into my EL. I've seen others, but they don't actually work when you press the button - this one does! ![]()
#27 | |||
#28 | |||
Miami Pilot
More work done during the night while watching the Aussies cream the Sri Lankans. Anyone notice my approx 5 hour mod here? Yes, it's a BA shifter adapted to fit the E series "stalk", and the mechanism inside reversed so that pushing the button activates by pressing on the stalk (the BA one normally pulls up the stalk), meaning all the detentes work, so you need to press the button to P-R, R-N, D-N, R-P & N-R & 2-1. One of the most small, challenging and yet rewarding mods I've ever done, because I had to engineer around an @r5e-about mechanism (thanks to Rollin for the inspiration, sort of).
#29 | |||
Miami Pilot
#30 | |||
i just wanted to see this one as it was talked about so much doing it in the AU love your work, NOW adapt the aston martin "flappy paddle" style gearbox for my AU..lol apparently better with a auto box anyways
