Old 16-05-2007, 08:34 AM   #1
james22
With da Warlords
james22's Avatar
Default Confirmation of correct part
Hi all.
I just need to confirm with anyone that would know, if this is the correct part for a L/H power window switch on AU3. I know that the switches are different between series II and III. I don't need the surround, just the switch itself.
James
AU2 14504 A1D BEZEL PWR WDW SW LH, SINGLE SWITCH, FROM 0801 IF REQD, USE $18.90
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2007, 09:34 AM   #2
JC
JC's Avatar
Best bet is to PM Russell, he is the king of Falcon part numbers. But the fact that it says "FROM 0801 IF REQD, USE " would suggest that there's a different part number that's missing from the description.
Your other option is just to ring ford and ask them. If you don't have confidence in your local ford dealer, the guys at John McGrath here in Canberra are very good parts looker-upperers - give them a call on 02 61222222 , ask them for what you want, and what the part number is, then go to your local ford place to buy it.
Ford Performance Club ACT
Old 17-05-2007, 12:42 AM   #3
FGII-XR6
FGII-XR6's Avatar
bezel means the plastic that holds the switch you need "AU2 14B134 A1D " SWITCH WNDW REGLTR, FROM 0801, SERVICED BY BEZEL AND SWITCH, FUTURA/FAIRMONT/FAIRLANE/GHIA, DK GRAPHITE $32.40 hope this helps
Old 17-05-2007, 08:42 AM   #4
james22
With da Warlords
james22's Avatar
Thanks. I always try to obtain the part no, as Ford constantly gets the wrong stuff in.
James
Windsor Warlords
AU III XR-8220
