horsepower
Need advice on what to do !!!!
I have a 2.5" custom exhaust setup that was installed by liverpool exhaust's. My problem is when i come to a stop at a set of lights for example,i begin to get vibrations through the whole car,like exhaust shaking and causing vibrations. I have since took it back to them and complained,and they said there was no problem with the exhaust touching any part of the undercarriage. So i then took it to Australia's best for a check, and they said" it was a defective resonator" so i got that changed. BUT IT STILL DOES THE VIBRATIONS ON AND OFF only in drive or reverse now???????? doesnt do it in neutral Any body else have this problem ??? |
Audi S3
its the idle.
mine does that as well. it idles slightly too low. im running a lukey 2.5" cat back exhaust. you need to clean the ISC (idle speed control) valve and it should come good again. for the time being, when you stop at lights, keep a very small amount of throttle on just to keep the idle up. if you notice, the car idles at higher revs in neutral.
horsepower
thanks HLC, yeah thats what i think it might be as well !!!
will cleaning the ISC help at all though ???? |
Ripping it up
my zorst was from livo exhausts too... nice and loud. it turned out the problem was when the engine decelerated, the pipe rattled on my irs diff. zorst rubber and some braided wire fixed that
#5 | |||
Audi S3
#6 | |||
Walking with God
Just in case you want to clean the ISC valve. I clean mine every few months or so, quick and easy job.
Sorry if you already know how to do this, just offering help. Cleaning ISC Valve http://www.fordforums.com.au/showpos...9&postcount=43 Cheers, GK
horsepower
thanks GK , i did the ISC and it's still plays funny buggers, and it's even starting to drop and pick up revs at idle in gear, i have checked plugs,leads are new,coil seems perfect and i am thinking it might be a battery issue or unichip needs a retune to even out the idle in gears
Clean or replcae your oxy sensor, I'll put money on it
horsepower
will oxy sensor cause it to idle bad ??
