16-05-2007, 01:37 PM | #61 | |||
Spr Jenkins
-Before Chuck Norris visited them, they were called "The Virgin Islands" Now, they're just "The Islands" -Mathematicians have found that due to the excessive amount of women Chuck Norris has slept with, it is guaranteed that he appears in your family tree a minimum of three times -Chuck Norris doesn't sleep. He waits. -Chuck Norris once worked as a weatherman for the San Diego evening news. Every night he would make the same forecast: Partly Cloudy with a 75% chance of Pain. |
16-05-2007, 02:06 PM | #62 | ||
My farther is the workshop foreman at our local ford dealers and as such road tests alot of new cars when doing the pre delivery. He said you used to come across the odd "freak" car that would go significantly harder than the typical example but not very often any more. He said EA's seemed to have the highest percentage of freak cars for some reason (probably due to the high amount of the opposite of the freak car, the dud with this particular model). Now days if they do come across something that is over or under performing on the road test a quick flash of the PCM usually fixes it.
16-05-2007, 02:15 PM | #63 | ||
Everyone i know seems to have a freak of a car
So they must all be freaks yeeeeeeeah !!! |
16-05-2007, 02:33 PM | #64 | ||
Holdens Fall Apart!
There not all freaks. Some people just think they have the fastest cars under the sun. And they dont.
AU2 XR8, Venom Red, 200kw, K&N Panel Filter, 2.5" Lukey Exhaust
16-05-2007, 03:16 PM | #65 | ||
Bear with a sore head
My old AU XR8 was a bit of a freak I think. It ran mid 14s with just a K&N filter, shift kit and straight through centre mufflers. 14.59@94mph and 152rwkw (APS dyno) for a series 1 XR8? Unheard of, as a lot of people doubted my credibility at the time!
16-05-2007, 03:18 PM | #66 | ||
XR5 Pilot
There was apparently meant to be a batch of XR6 Turbo's that came with significantly higher standard Boost levels...from what I remember reading, you could tell them appart as the Turbo was marked with Blue Paint Pen.
'08 Ford Mondeo XR5 in Thunder |
16-05-2007, 04:29 PM | #67 | |||
16-05-2007, 04:36 PM | #68 | |||
16-05-2007, 05:35 PM | #69 | |||
Now XR8TickfordBoy
EF XR8- Respray in Monza Red with Clear Coat, Custom Rear Bar, AU V8, EL GT MAF, Rebuilt and Strengthened Auto with Stage 2 Shift Kit, 2,500RPM Stallie and tranny cooler, Rebuilt Diff with 4.11 Gears, Custom Radiator, King Ultra Lows, Pedders Shocks, NL Concorde Rims. |
18-05-2007, 05:00 PM | #70 | |||
Peter Car
18-05-2007, 05:16 PM | #71 | ||
The Vengeful One
I think they are out there, a guy i worked with once had an xd wagon with a 302 in it would blow anything it came across away, it had just extractors and was lowered a bit, but the thing was an animal, you could plant it at 80 and it would break into wheel spin (it was a 3 speed auto) it scared the shite out of me! Also used less fuel and ran smoother than his xd sedan, so i say this thing was a freak!
18-05-2007, 05:39 PM | #72 | ||
There will always be some power variation, but too much just indicates poor tolerance issues.
18-05-2007, 06:08 PM | #73 | |||
Peter Car
18-05-2007, 06:36 PM | #74 | ||
at the end of the day unless you owned the car from new or bort it of a reliable mate you have no idea what the previous owner has done in regard to mods or running in proceedure unless u pull it to pieces .the notion of freak cars that are essentially controlled by the ecu seems a bit of a strech to me and is more likely to occur in the days before the ecu was implemented into cars .its nice to think that your car is some how a little bit better than the average one but with more stringent quallity control in industry these days you would expect it not too happen.having said that recalls still exist dont they
