Old 16-05-2007, 08:11 PM   #1
Keith61
Default Engine check light ?
Hi all
I have a 2000 Au xl tray that I have just got and there is no book with it (have been looking for one )
I am asking if there is a engine check light on the Au as I cant find one
When I turn it on the
Oil, battery, Temp, low fuel, Handbrake if on and door a jar if open
Air bag and Seat belt light comes on then off
As I start the car the ! light comes on then off once started
There seam to be some fuse and a relay missing from the fuse inside the car But they could be for extras that are not on this car
Havent checked the other fuse box let was waiting till I had a book
Does anyone know if there is a download of a service book for the au
Thanks Keith
Keith61 is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2007, 10:25 PM   #2
AUXRVIII
Hey there, welcome to the forums.
No check engine light on AU. It's normal to have vacant slots in the fuse panel, same panel is used for all Falcon models and fuses are fitted where required.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2007, 10:30 PM   #3
Keith61
Ok all my others EFI cars had one ,So How does it tell you if there is somethink wrong
thanks Keith
Old 16-05-2007, 10:39 PM   #4
AUXRVIII
Generally the Falcon EFI system is very basic, no EGR setup etc, so not much can have an effect on emissions. The engine light is usually in place for emission reasons.
Old 17-05-2007, 12:24 AM   #5
Keith61
ok but they still have o2 and map sensors ?. surely they would have a warning system or is it like the Honda's PGM F1 that has a flashing led on the unit it self and you just look up the code
Or that you cant tell till you pug in a computer .
Old 17-05-2007, 12:31 AM   #6
Keith61
Ps I did notice the lack of a lot of vacum hose's didnt put 2 and 2 together till you said thort it was mainly due to it being a inline 6 in sted of a V
Thanks keith
Old 18-05-2007, 08:05 AM   #7
Mechan1k
Mechan1k's Avatar
There are other systems in place .... for airbag system for instance ... if there is a fault with it ... it will flash the cluster light for a code (3 times in succession and then stay on).
I guess the only real way of tell if there is a fault is if the car runs a bit off ... uses a lot of fuel (more than normal) .... or just doesn't start I guess. You can get this checked by Ford ... or by another mechanic who as access to a Scantol that can plug into the Ford diagnostic plug (located in the incabin fuse compartment on the right).
Old 18-05-2007, 08:12 AM   #8
Casper
Contributing Member
Casper's Avatar
Heres a manual for you, this might help:
http://members.optusnet.com.au/petav...box_Manual.zip
Older, wiser, poorer.
Old 18-05-2007, 10:55 PM   #9
Keith61
Yes that manual was most helpful thankyou
Old 18-05-2007, 11:06 PM   #10
Mechan1k
Mechan1k's Avatar
Thanks for the link Casper ... even though i have a book already ... it's good to have online.
