Old 16-06-2007, 06:07 PM   #1
ace16
Default Help with removing rotor
Today I attempted to replace the rear rotors and pads on my Au fairlane.
The caliper came off fine, However I could not remove the rotor. Any suggestions?
- I have removed the locating screw from the rotor.
- Yes, the handbrake is off and the hub spins freely.
I've tried negotiating with it using a mallet, doesn't budge from the hub.
I am assuming the the rotor has coroded to the hub? or have I forgotten something?
Any suggestions or ideas will be greatly appreciated!
ace16 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2007, 06:21 PM   #2
RG
Back to Le Frenchy
RG's Avatar
I would say corrosion is holding it on. Let it soak in WD40 for a while then have another go with the mallet.
Old 16-06-2007, 06:28 PM   #3
ace16
Thanks Red.
I'll give the WD a go in the morning.
Old 16-06-2007, 06:29 PM   #4
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
yup that's most likely will have happened and what you'll have to do. Look at the bearing cap(or what i call the bearing cap, part in the middle that sticks through the rotor) and you'll see it's rusted.
cheers
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 12:06 AM   #5
EvilChief
Boost Addict
why mallet? bring on a half decent sized hammer, hit it well on each side of the inner hub of the rotor (not on the friction surface) that should break enough corrosion free
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 12:41 AM   #6
Firefox7
T3 Terrorist
Firefox7's Avatar
Mate..your car has a caliper system for braking performance, but the handbrake is like an old shoe system that sits in the rotors well. No ammount of bashing will remove it. If you rotate the rotor to say 9'oclock position with the largest hole as reference...you will see... if you have a torch...a bunch of teeth in a horizontal position...it's hard to spot. Once spotted use a flat head screw driver and push it away from you..this will loosen off the internal handbrake actuator. Loosen enough will release the rear rotor with ease.
Proud Owner of a Tickford TE-50 T3 No 033...13.16@107.12 mph 1.868 60"
Fastest Lap time At wakefield park on Dunlop Sp9000's : 1:14:30, Came 2nd in outright driver, in the overall V8 result, 2006 N.S.W dutton rally :1syellow1
:king: T3 :king: The Mightiest & Deadliest Tickford Ever To Hit The Road........
Firefox7 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 07:44 AM   #7
GK
Walking with God
GK's Avatar
Chief is spot on. I put some serious dings in my old rear rotors on the SR to get them off. Smack the heck out of them, you're replacing them anyway. Also, sand / remove the rust around the hub that's been holding them on! LOL! You may want them off in the future for modding or such and you wouldn't want the same dramas! LOL!
I've never had a hint of trouble with fronts though.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 17-06-2007, 09:35 AM   #8
ace16
Thanks for all the help guys. I'll have another crack at it this morning and let you know how I go.
Its amazing how helpful you all are, I only signed up yesterday and lodged this thread out of desperation.
Many thanks for all the feed back.
Old 17-06-2007, 03:50 PM   #9
ace16
Done. Corrosion was the main problem, But also had to adjust the handbrake as well to pull the rotors all the way off.
Thanks guys
Old 17-06-2007, 08:22 PM   #10
EvilChief
Boost Addict
Thanks guys
ah the good old overadjusted handbrake trick ... go them at work every day :
N12 Pulsar - sold
