Old 15-06-2007, 09:22 PM   #1
eXi7w0unD
eXi7w0unD's Avatar
Default wheel spacers
where can i get wheels spacers, im after either 2inch or 3 inch. just for the rears. any downside/upside to wheel spacers too? anything i should know?
cheers
i won.
eXi7w0unD is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2007, 09:30 PM   #2
Casper
Contributing Member
Casper's Avatar
they will change the handling dynamics of the car (for the worse if you move the unsprung wheel weight out another 2 or 3 inches)... they are illegal.. your insurance will be void.. probably something you should know.
Older, wiser, poorer.
Old 15-06-2007, 09:38 PM   #3
eXi7w0unD
eXi7w0unD's Avatar
but they make my car look hell sexier right...?
i won.
Old 15-06-2007, 09:39 PM   #4
99XR6
99XR6's Avatar
why do you want 2 or three inch spacers anyway? that is a massive change in offset.
99XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2007, 09:40 PM   #5
Casper
Contributing Member
Casper's Avatar
yeah.. you can drool over the pics of it all you like.. and even continue to pay it off along with the BMW that hits you and has insurance.. and you don't cause your insurance company wipes you when they find out you have spacers.
Old 24-06-2007, 10:29 AM   #6
eXi7w0unD
eXi7w0unD's Avatar
i found out that wheel spacers can be legal if they are welded on. if they have been bolted on thats illegal
thanks to boostcruising forums
i won.
Old 24-06-2007, 10:55 AM   #7
V3RSAC3
... Fear it!
V3RSAC3's Avatar
you can get them from any tyre/mag shop ... but there not cheap
Originally Posted by Mr Hardware
Just remember gents, anyone can follow fashion, but it takes someone with real class and finesse to have Style.
Chrysler 300C Sedan
SY Territory Ghia
V3RSAC3 is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2007, 10:58 AM   #8
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Don't rely on what someone eles tells you on a forum. Go to you local road authority & check with them.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2007, 11:03 AM   #9
JC
Miami Pilot
JC's Avatar
cheers
I had a set of 17 x 8 E series offset wheels (approx 35mm less offset than AU offset) bolted to the back of my old AU1 XR6 and even with rolled guards, the tyres hit the inner edge of the guards and pulled chunks out of the tyre.
I also had a set of AU offset 9" rear rims on the back, and these did not foul the outer guards, but were very close to the inner plastic guard. An extra 1" in rim width is basically an extra 1/2" of rim on either side of the rim centreline, and this size rim fills the guards very well - 9.5" is probably the max you can go on a sedan, which is 38mm wider than an 8" rim, or an extra 19mm each side of centreline.
Based on this, if you used a 20mm (3/4") spacer, you would probably be OK, but 2" or 3" would definitely have the guard ripping chunks out of the tyre, unless you had the guards severely flared. If you use a 20MM spacer with 75mm wheels studs, you may be OK in terms of having enough thread keeping the rim on, but you still have the problem of the locating centre of the hub not holding the weight of the rim - this is why spacers are generally illegal, as it relies on the wheel studs holding the weight of the wheel, when they are only designed to hold the wheel on, and the weight of the rim is actually supported by the centre part of the hub.
Ford Performance Club ACT
Old 24-06-2007, 08:39 PM   #10
bodes-sh
^^the other way you can get around tyres scrubbing outer guards is if you have irs to run as much rear camber as a vt commodore, then you only have to worry about scrubbing the inside edge of the tyres off because they are at a 45 degree angle to the road...
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
