15-06-2007, 08:15 PM | #1 | ||
[EBGLT]
Well due to the recent unfortunate events of the EB blowing out the rear main and the sump gasket on its way out a month ago. I started pulling her apart and first things first.
I knew that there would be alot of oil everywhere but I was not expecting this. 3 Welsh Plugs Noticing lots of other little problem on the way like the turbo mainfold bolts had worked loose which would cause power loss under load just alot of little stuff like that. At the moment I am pulling this motor completely out. The 3.9 has seen better days and has stood up to the task producing 163.6rwkw@3psi. But now I want more power. At the same time im building a ED XR6 Tickford motor for it. Fitting: Higher Volume Oil Pump Bigger Fuel Pump Higher Volume Fuel Reg to keep up with Vortech system. Boost Controller DeComp Plate Blow Off Valve Motec M8 And lots of other little goodies. Currently aiming to push the 12psi barrier and aimng power well over the 200rwkw mark. Hopefully finished within the next month. SnyperEB
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
15-06-2007, 08:18 PM | #2 | ||
MADED.6
sounds good man cant wait to see it finished. put stokcies on it with hubcaps like ebmanul that thing is the biggest sleeper.
if u need any help let me no man. cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
15-06-2007, 08:32 PM | #3 | ||
The one and only
I don't think ya head bolts are tight! Ha ha
Good work Shaun, it will not take long to crack the 200rwkw.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
15-06-2007, 08:35 PM | #4 | |||
[EBGLT]
15-06-2007, 08:43 PM | #5 | ||
ORSM Ford Cruisers
sound like fun. good to see a e-series turbo getting some attention.
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread 2008 FG XR8 SEDAN 300RWKW N/A 2008 FG XR6 TURBO-UTE>>> SOLD 2002 AU3 XLS UTE>>>SOLD |
15-06-2007, 08:47 PM | #6 | ||
:D:D
this is going to be good when its finish mate, cant wait to see you go up against that EAT at calder park again :P
Cheers Grant |
15-06-2007, 09:16 PM | #7 | ||
good stuff...where u getting the decomp plate from?
15-06-2007, 09:18 PM | #8 | |||
[EBGLT]
Recieving decomp plate from Dan.
http://eseries.com.au/index.php/membership/ Last edited by snypereb; 15-06-2007 at 09:25 PM. |
15-06-2007, 09:29 PM | #9 | ||
MADED.6
no dont put a decomp plate on.
i put one on mine coz a head place shaved my head wwwwwwaaaaaaaayyyyyyyy to much and it blow the headgasket in 5000k. just my 2c. cheers josh.
15-06-2007, 11:59 PM | #10 | ||||
The one and only
Kidding man, 220rwkw is awesome power.
16-06-2007, 12:22 AM | #11 | |||
Tuned @ Pitlane Frankston
engine looks good shaun.. any reason why you didn't chuck an AU engine in there instead of the ED XR?
16-06-2007, 10:30 AM | #12 | |||
[EBGLT]
16-06-2007, 11:16 AM | #13 | ||
Last warning
cheap replacement engines are great! :P
i better get my act together and get a better engine for mine. or just put the 11psi wastegate spring in and see how long the current one lasts.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
16-06-2007, 11:38 AM | #14 | |||
The one and only
Shaun is at least running 12.. :P
16-06-2007, 11:52 AM | #15 | |||
Last warning
16-06-2007, 09:35 PM | #16 | |||
[EBGLT]
24-06-2007, 05:26 PM | #17 | ||
[EBGLT]
Thought I would post up some recent pics got into some serious work yesterday and today. Yesterday organising turbo motor with CVE Performance and today pulling out the old motor and starting to clean out some of the mess that it has left behind.
SnyperEB
24-06-2007, 06:09 PM | #18 | ||
The one and only
Looking good Shaun.
Thanks for the update
24-06-2007, 06:12 PM | #19 | ||
MADED.6
looking good man should be back on the road soon huh.
cheers josh.
25-06-2007, 04:25 PM | #20 | |||
Nice work Shaun. I'll give you a run when you've got her back on the road :
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
25-06-2007, 06:10 PM | #21 | |||
[EBGLT]
