Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 27-07-2007, 05:14 PM   #1
XR8-260
Default bluepower cai
I'm in Perth and was wondering where I can get the bluepower intake for my BA XR8?
Cheers.
XR8-260 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 05:18 PM   #2
DOC
DOC's Avatar
Cheers.
3 I'm sure if you pop over and see Craig at ACE ( Send a PM ) he will sort it all. One thing for that i have noticed with your new XR is you a fast learner and on the Money
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 07:38 PM   #3
XR8-260
Cheers mate.
Old 27-07-2007, 08:31 PM   #4
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
Cheers.
Good idea 3, one of these style airbox's is a must on these beasts.
FPV8U is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2007, 07:58 AM   #5
Bluepower
KenneBell Australia
Bluepower's Avatar
Cheers.
PM sent.
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 12:52 PM   #6
Powdered Toast Man
Professional Mouse Jockey
Powdered Toast Man's Avatar
Is there a trick to installing these?
I recently bought one second hand for my 3V but as far as I can tell there is what I think is an airconditioning pipe in the way down the right hand side (engine side) of where the side of the airbox should sit.
Also is the windsreen washer bottle relocated or does it fit inside the airbox?
What do you do with the oil breather line that plugs into the OEM intake at the throttle body?
Thanks,
Paul
Isuzu MUX for towing horses - currently no Fords in the stable
Time flies like an arrow; fruit flies like a banana. Groucho Marx
Powdered Toast Man is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 09:45 AM   #7
Chris
AFF.com.au
Thanks,
Paul
Hi Paul,
The windscreen washer bottle remains in its location, with the fill tube residing under the lid.
The airconditioning pipe needs to be pushed away fom the airbox, it requires adequate clearance or it will wear through.
Bluepower 3v kits are supplied with an A.C.E inlet pipe - this has a fitting supplied for the said oil line, however if you purchased your kit from Paul (CVE) he has made up his own system, might be worth PMing him so you get the lowdown on what to do.
Chris
Chris is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 11:22 AM   #8
Powdered Toast Man
Thanks Chris. It is a CVE pipe; I bought it from sfr rob, came off his 3V Ghia.
Old 30-07-2007, 03:57 PM   #9
Bluepower
KenneBell Australia
Bluepower's Avatar
PM V8Capri (paul), great bloke, he will help you with your dilemma, no probs.
Chris
