10-09-2007, 11:56 AM | #1 | ||
Flairs - Truckers Delight
Howdy chaps
I have a big problem with my June 2000 AU2. The speedo flails around like mad, no matter whether you're in drive or neutral or park. This causes the automatic to select the wrong gear. I have had the speedo outer gear replaced, the transducer replaced, the speedo inner gear replaced all to no avail. Now here's the weird part. I have tried 3 AU2 clusters and they all display the same symptom. If i use an AU1 cluster, it fixes the problem. Now that would be okay except i don't particularly like the AU1 cluster, i'd prefer to keep the car as original as possible. Can anyone shed some light on this? Cheers Mr Hardware
11-09-2007, 11:29 AM | #2 | ||
