Old 20-08-2007, 06:36 PM   #1
wazza69
wazza69's Avatar
Default AU Fairlane 5.0L Vibration
Hi Guys,
I recently bought a Series 1 AU Fairlane. It has a vibration in the motor around 1200RPM. Now I've searched all the forums, and came across some things to try, this is what I've done:
Replaced Spark Plugs (NGK Iridiums)
Replaced Leads (and checked each one's resistance - all were fine - around 4 ohms)
Cleaned the throttle body
Cleaned the ISC Valve
Reset the ECU
and it's still got the vibration! Any ideas on anything else to check before I send it in for someone to look at - maybe its the injectors or something...
Current Rides:
2015 Ford Transit Custom
1967 ZA Fairlane 289W - Thread: https://fordforums.com.au/showthread.php?t=11456233
2005 Suzuki GSX1400
wazza69 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2007, 10:00 PM   #2
V8falcons
V8falcons's Avatar
Originally Posted by wazza69
Hi Guys,
Reset the ECU
Is the vibration @ 1200rpm in netual,or taking off?
harmonic balancer,or uni joints maybe.
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2007, 11:28 PM   #3
wazza69
wazza69's Avatar
both neutral and driving, but much more noticeable when driving.
I'll look into the harmonic balancer, thats one of my 'could be stuffed' options...
Current Rides:
2005 Suzuki GSX1400
Old 21-08-2007, 12:25 AM   #4
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
I did my harmonic balancer and you would know if it was broken the whole car feels like theres an earthquake in it. I have a friend who's fairmont was doing this turned out to be that 2nd gear was rooted in the auto and the motor was running in limp mode. It was a chic though and she had no idea on what was going on. she didnt even realise the car wasnt going into 2nd or 4th
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2007, 12:36 AM   #5
wazza69
wazza69's Avatar
Haha no the gearbox changes gears fine. Sometimes when I put the boot in, it backfires too... it only vibrates around 1200, above that its ok, so I'm guessing that rules out the harmonic balancer... I might change the fuel filter and see what happens.
Current Rides:
2005 Suzuki GSX1400
Old 21-08-2007, 02:00 AM   #6
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
you could have one of you cats on the way out? when you put the boot into it the exaust fumes can puch the broken bits up so it flows then at low revs they block it again. I also had this happen to mine when it fully collapsed you could put your foot down and it would go fine then other times you can put your foot down and it would shake and gargle and back fire. Easy way drop the pipes of at the front and shine a torch up the cats.
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 21-08-2007, 02:25 AM   #7
wazza69
wazza69's Avatar
cool, another one to add to the list! Thanks mate i'll check it out.
Current Rides:
2005 Suzuki GSX1400
Old 30-08-2007, 06:07 PM   #8
wazza69
wazza69's Avatar
Well I had a call from the injector place, they checked all the injectors and they were fine, they did tests on the cylinders, and no 7 is playing up, however all the leakage tests showed up fine - so they're thinking it may be the camshaft... which means money, which sucks for me!
Getting my mechanic to look at it asap, and see if it really is the camshaft. If so, may as well put a bit extra cash in and put a better cam in hey ;-)
Current Rides:
2005 Suzuki GSX1400
Old 30-08-2007, 06:43 PM   #9
stavros68
most likely a harmonic, does it mis under load?? i had the same problem thought it was the auto looked at the harmonic and saw the rubber trying to part company
stavros68 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2007, 11:22 AM   #10
S3SR
S3SR's Avatar
if you only recently bought it wouldnt the roadworthy certificate cover it?
sorry im not all clued up on this stuff, but id look into it
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2007, 04:20 PM   #11
wazza69
wazza69's Avatar
It misses a little under load, but doesn't vibrate like it does around 1200rpm. I bought if off a mate - private sale. He thought it'd just be a tuning issue, as did I!
Current Rides:
2005 Suzuki GSX1400
Old 16-09-2007, 10:34 PM   #12
wazza69
wazza69's Avatar
All fixed, it was the Harmonic Balancer! Happy days...
Another problem however - there's a box in the front left mudgard in front of the wheel just behind the plastic protector, and its ticks quite loudly - not a steady ticking, but all over the place (rhythm wise), any ideas what this is??
Current Rides:
2005 Suzuki GSX1400
Old 16-09-2007, 10:42 PM   #13
wazza69
wazza69's Avatar
Just did a quick search, seems like its a common problem - its the purge valve. I'll wrap it up in sponge & cable tie it and see if that fixes it
Current Rides:
2005 Suzuki GSX1400
Old 17-09-2007, 12:27 AM   #14
peterban
AULTD
peterban's Avatar
I don't think you are supposed to clean the throttle body on the V8's as they have a special coating on the inside of them.
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2007, 02:48 AM   #15
wazza69
wazza69's Avatar
yeah??
Current Rides:
2005 Suzuki GSX1400
Old 17-09-2007, 06:55 AM   #16
howesy
howesy's Avatar
I was always told the same about the coating and to avoid using throttle or carby clean but was also told that WD40 on a rag was the best and safest thing to use on those throttle bodies. I either use a very soft dry cloth or the WD40 every once in a while and it works a treat and keeps the idle fine.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2007, 01:38 PM   #17
wazza69
wazza69's Avatar
I just found the throttle body clean for the 6 thread and assumed the 8's would be fine to do it too as well... too late now, I've done it!
Current Rides:
2005 Suzuki GSX1400
