Old 25-05-2005, 03:16 PM   #1
XRated
Shoot.
XRated's Avatar
Angry FFS, what is it now?
Wellll my latest problem.. Sorry it's a bit hard to understand but I can't explain it very well unless you're actually sitting in the car.
Basically when I floor my car, something is happening at the rear. It's kind of like a "clunk clunk knock" struggling sound. At first I thought it was fuel related (crap fuel, need new plugs/leads or something), but now I can feel the knock so I am thinking it is probably somthing physical like the diff. If you think of an exhaust being loose and knocking under vibration it's a bit like that..
What is it this time? :togo:
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2005, 05:11 PM   #2
Dezza
Parts bin special
Dezza's Avatar
Try checking the rear universal joint. If it has some slop in it, it could be vibrating and hitting the underbody.
If it's any help, a dodgy engine mount caused my engine to sit a little low in one corner, which moved the driveshaft a little bit out of place, enough to cause the rear universal joint to knock against the body under acceleration. Gee it sounded bad. But I'd check the universal joint first.
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2005, 06:43 PM   #3
*rayman*
454 Power
*rayman*'s Avatar
could be trailing arm bushes, they get progressively worse and noisier over time
DAILY - 00 75th Anniversary Futura
TOY - 68 SS 454 Camaro
*rayman* is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2005, 10:00 PM   #4
InitialD
Low and Loud
InitialD's Avatar
Could be as others have said
* Trailing arm bush's worn
* Universals on the tailshaft
* Diff whiplash
Id say its one of those, Also did you change your transmission mount yet? because mine is slogged out and is making my trans knock about
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2005, 10:21 PM   #5
EB6
apprentice grease monkey
EB6's Avatar
yeah trailin arm bushes do jusp to mind, the diff would tend to be more worse on decel or just noisy in general when its not loadin from my experience.
EB6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2005, 08:58 AM   #6
EA2BA
PM me if you want
EA2BA's Avatar
trailing arm bushes, the uni's looked in good condition when I have been under your car Luke.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2005, 11:35 AM   #7
XRated
Shoot.
XRated's Avatar
Thanks guys. Are trailing arm bushes a DIY job, or something for the pros? What do they cost?
20V Turbo
Old 26-05-2005, 03:10 PM   #8
InitialD
Low and Loud
InitialD's Avatar
Luke, you can buy Reco trailing arms complete with bush's allready fitted, etc
I have reco lower ones in my EA. I think its like $100 for a Pair LOWER and $80 for a pair Upper
Old 26-05-2005, 03:18 PM   #9
EA2BA
PM me if you want
EA2BA's Avatar
Bush replacement is an expert job, trailing arm removal and replacement is a DIY.
Old 26-05-2005, 03:31 PM   #10
XRated
Shoot.
XRated's Avatar
Might just get new trailing arms. Mick, where is that from? Repco?
20V Turbo
Old 26-05-2005, 03:39 PM   #11
InitialD
Low and Loud
InitialD's Avatar
I got them from a wreckers near me. When your on msn next ill give you the info
