Old 01-10-2007, 08:45 PM   #1
Rickoman
Rickoman's Avatar
Default Welding a new tail pipe on my AU
Hi all, I can't find anything on this in any threads so here goes.
I want to weld a new tail pipe on my 2001 AUII Futura and was wondering if I should disconnect battery?
If so, what sort of problems will/could I come up against once I reconnect battery? Any problems???
Battery would only be disconnected for a very short time.
Thanks regards Rick.
Rickoman is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2007, 08:54 PM   #2
Kryton
Kryton's Avatar
youll need the code for your stereo if you disconnect.
apart from that, i cant think of anything else that would be affected.
Old 01-10-2007, 09:01 PM   #3
blackers10
blackers10's Avatar
you just need to follow the ecu reset procedure (do a search)
On The Street Feature Winner Performance Ford Mag
See my car at:-www.aufalcon.com/blackers10
blackers10 is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2007, 09:23 PM   #4
mik
mik's Avatar
usually its good practise to disconnect the battery , i`m interested to hear info about this, doing my exhaust we did the whole job on the ground , we did`nt know wether it would affect the computer or not
Old 01-10-2007, 09:38 PM   #5
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Is that necessary everytime i disconnect the battery for long periods (over night)?
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2007, 10:05 PM   #6
Rickoman
Rickoman's Avatar
Hi Blackers10,
I did a search in here and found how to do the ECU reset procedure for my AUII.
Thanks mate and thanks to the others for their input.
Rick.
Old 01-10-2007, 10:14 PM   #7
EX-Y494
EX-Y494's Avatar
No it's not necessary to do it everytime.
Proud member of the All Ford Club of QLD
_____________________________________________
98 AU FORTE-Congo Green
C2R body kit, 2 1/2 cat back Exhaust, Red Diamond 2800rpm stall converter
BA front brakes, BA air box with pod
http://www.aufalcon.com.au/cgi-bin/i...act=item&i=326
EX-Y494 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2007, 07:27 AM   #8
blackers10
blackers10's Avatar
i thought if it was a long period you had to redo it ex-y494??? as the ecu has forgotten whats what.???
Old 08-10-2007, 07:38 PM   #9
Rickoman
Rickoman's Avatar
Hi again,
All went well with the tailpipe welding. Didn't have to reset ECU as battery only unhooked for very short time, just had to recode the radio/cd player.
Thanks for your help.
Cheers Rick
