Old 04-04-2006, 11:11 AM   #1
robbo_yobbo
Kick out tha Jams
robbo_yobbo's Avatar
Default installing sunroof
just wondering if has anyone put thier own aftermarket sunroof into thier AU?
I purchased a universal sunroof that I intend to install myself, but was just wondering if hacking away at my roof would cause any damage to the structual integrity of the car (I heard the roof provides quite a bit of structual support).
Are there likeley to be any crossmembers that need to be cut and modified around the sunroof?
Is this a job best left to a pro, or is it as basic as I am hoping....?
any pointers before i pull out the angle grinder and tinsnips would be great, cheers.
robbo_yobbo is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 12:27 PM   #2
Aggerz
Question
damn i just did a forum search and been digging for the same answer..
Anyone help?
Aggerz is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 01:34 PM   #3
LG
LG's Avatar
Someone wrote up, something on fordmods.com, about doing this to an e-series.
Just hope you get the seals right. Otherwise hello water!!!
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 07:57 PM   #4
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
i got two words for you , Rust Killer ~!~
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2006, 10:00 PM   #5
trick_xd
I build your wish list...
trick_xd's Avatar
Hey Guys Sorry to bring up a sort of old thread
I just put in a sunroof into my EL on 24.april and i have a few pics if you want
It realy is very easy Just have to work out what you want to do then how to do it then mark it out .. remark it out then cut
Sounds easy but it took me 4 hrs on monday and it is a week later and i have pressure washed my car 3 times went through a car wash 1 time and sits out in the rain all the time .. AND still NO leaks so i think its great Let me know if you want some pics .
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2006, 08:42 PM   #6
robbo_yobbo
Kick out tha Jams
OK, i decided to do it myself to save cash, and now that its done, I'm glad I didnt fork out $ for someone else to do what was reletiveley simple.
Other than saving money, It gave me inspiration to start the re-upholstry of the car in white vinyl too
If anyone else is looking to do the same just as a referance this is how i did it and ive had no leaks.
- remove your roof lining for starters so you dont set fire to it
- cover up the interior of the car with a woolen blanket so you dont get burn holes from anything
- I cut a template out of cardboard to match the fitting size of the sunroof and traced it onto the roof with a whiteboard marker
- cut the roof out with an angle grinder (while my mates told me i should take it to a professional thinking id 'ForK' it up), might I add, dont do this on a wet day - lol
- the sunroof slotted straight in and sealed it outside and in with silicon adhesive
- cut a hole in the internal roof liner slightly larger than the sunroof
- bought a big sheet of vinyl (cost about $12) and some spray on contact adhesive and put the 2 together using a hair dryer to make the vinyl more plyable
- sprayed all the trims with blue paint as contrast to the white and put it all back together.
- More than happy with the result, no leaks, it gives the feeling of a bigger interior with the sunroof, and with the new vinyl roof and blue trims the car looks like its worth $4000 over what it used to. (also theres no holes where there used to be a ''taxi" sign!)
Would recommend anyone to do it themself, it took less than 2 hours to install.
Old 23-10-2007, 10:35 AM   #7
BigBastard
I want to go fast...
BigBastard's Avatar
do you have any pics? during the process pics would be great but i think i am pushing it :P
BigBastard is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 07:01 PM   #8
xr8 007
xr8 007's Avatar
how much does it cost for a profesional to do it? I so dont have the B@LLs to do it myself.
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
