Old 06-06-2005, 10:59 AM   #1
351GT
Default Xb Sedan Scuttle Tray Painting.
Hey,
Ive got an xb gt sedan and i need to work out the way you are supposed to paint the scuttle up to suit the bonnet. Wondering what gap you should use in between the inner and outer black lines.
Can anyone give me the proper dimensions,
Like measurements to start 1st black line, gap between the 1st black and the middle black strip. Would be much appreciated. thanks
351GT is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2005, 01:40 PM   #2
351GT
anyone?
Old 07-06-2005, 06:09 PM   #3
smciner1
Detroit Locker Equiped TM
smciner1's Avatar
Okay. Just measured the bonnet on mine.
The main contrast panel (Low Gloss Black or Silver) is hard against the edge of the last pressed vent in the Scuttle. The gap between it and the outter stripe is 1/2". The Outter Stripe is 5/16" wide. The Stripe and painted out patch go straight down the bonnet to the Scoops, whee they then follow the curve pressed into the leading edge of the Scoops. The Contrast panel and Stripes end 1/2" from the leading edge of the Bonnet.
Trust this helps.
Apollo Blue 1974 XB Falcon GT, 557 HP
Blue Pearl 2004 BA FPV GT, 290 kW
Originally Posted by MRJUCY
Simple give the car a rev & have a listen a Windsor makes a sort of wheezy drone similar to an angry Hugh Grant when a Clevo will sound like Satan has woke up with a hangover & realized he is out of coffee & cigarettes
Falcon GT Club of Geelong.
http://www.facebook.com/FalconGTClubGeelong
smciner1 is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2005, 06:27 PM   #4
NAK302
NAK302's Avatar
i always thought the stripe and the gap should be 5/16"
NAK302 is offline   Reply With Quote Multi-Quote with this Post
