Old 03-02-2008, 08:20 AM   #1
T3rminator
T3rminator's Avatar
Default Vibrating clutch pedal
My clutch pedal has developed a bit of a rattle, usually when accelerating through around 3000RPM. I took a quick look underneath lastnight and there is about a 1mm give of the pedal from left to right. This is enough to make the noise. I looked around for a bolt or nut to do up but can't seem to locate one. Any ideas on how to "tighten" it up?
Rides (past and present)
Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual
Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m)
AFF motto - If contrary views trigger, please use ignore button.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2008, 10:49 AM   #2
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
I would guess at a broken clutch return spring mate. A Broken one won't keep the tension on the pedal and make it vulnerable to vibration.
Or a cracked firewall/clutch adjustment. You can adjust the clutch by pulling the cable from inside the engine bar gently enough to take the tension of the nut and spin the nut by hand in most cases to alter the travel of the clutch. Should be adjusted so the clutch pedal is about the same height as the brake pedal and then see how the take up feels from there. Spin anticlocwise (loosen the nut) to lower the pedal and vice versa.
Sorry, if it lateral movement I would say this is pretty normal actually. Wouldn't hurt to check for either of the other things though.......
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2018 Ford Ranger RAPTOR
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2008, 11:29 AM   #3
T3rminator
T3rminator's Avatar
I did check the spring and its ok. Could be weakening? Where do I get a replacement one from?
I do 'play' with the clutch adjustment from time to time....maybe I have it set too high.
