Old 23-11-2007, 05:59 PM   #1
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
Default Dash light out?
Hey guys
Just wanted to know, are there globes behind the odometer? Half of the odometer section is out, odometer reading is still visible just no light behind it. But the other half, where the km's left part on the left is stil lit up?
Any thoughts guys
cheers
Current car
94 ED Fairmont 5L in Burgundy
Fords ive owned-
2010 FG XR6 5 speed auto in Mystic
81 XD S-Pac 302c 4sp manual
78 Yellow TE Cortina Wagon 4.1L
92 Green EB Fairmont GT replica
01 Black AU XR8 II Manual
04 Rapid BAII XR6T 220rwkw
04 Mandarin BA XR6T 247rwkw
07 BF II XR6T 385rwkw
1980 ZJ Fairlane 302c
mr302xd is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2007, 06:58 PM   #2
aye you
The Origional, The Best
aye you's Avatar
not globes, but LCD, sounds like the crystals are dead. but i could be wrong
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2007, 08:14 PM   #3
b2tf
not here much anymore
b2tf's Avatar
Fraid that yes you are wrong, there's 2 globes behind there, i replaced one in a mates ute the other day with the exact same issue. Pull the cluster out, then youll be able to rmeove the globes. Take the blown globe out of the holder and whack a new one in, reassemble - all done.
2024 F150 XLT
Old 23-11-2007, 08:34 PM   #4
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
ok kool thanks for that.
Is it an easy job? Probably sounds stupid askin that but i havent pulled one out before. Gotta start somewhere i suppose
cheers
Current car
Fords ive owned-
Old 23-11-2007, 08:45 PM   #5
aye you
aye you's Avatar
lol i usually am
Current Mods
Future Mods
Old 23-11-2007, 09:09 PM   #6
b2tf
b2tf's Avatar
cheers
Yup, if you have a look at the cluster, at the top there's 2 black plugs, you can pull em out with your finger. Philips head screws behind them, take those out, then pop out your fuel/bootlid release buttons, stick a big long screwdriver up behind the cluster, and carefully prise it out. Make sure youve got the whole thing because the mask (plastic bit over the front of the cluster) can come off on its own, and you dont want it to break.
Once the cluster's out, you'll see 2 looms, they plug into the back of the cluster at opposite ends, unplug them (you cant put them back in the wrong way as theyre different connectors so dont worry),then you can pull the cluster right out of the car. From there you'll be able to get the bulbs out.
Refitting is the reverse, when you start the car again you might see the dash display a "t" for a few seconds - this is normal.
2024 F150 XLT
Old 23-11-2007, 09:21 PM   #7
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Not hard
2 screws under little plastic caps, carefully lever cluster forward, unclip wiring plugs, lower steering wheel and pull out
turn over and you can see 2 or 3 grey bulb holders along the top, they are the backlights
the black bulbs are the warning lights, it's a good idea to check these while it is out as well, check with multimeter
the small odometer ones need a screwdriver to remove
use long nose pliers to twist and pull to remove the larger ones
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2007, 09:22 PM   #8
Jastel
Beat me to it!
Old 23-11-2007, 09:25 PM   #9
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
Thanks for your help guys. Ill give it a crack tomorow
cheers
Current car
Fords ive owned-
Old 13-03-2008, 05:03 PM   #10
FOON
Thanks for the info guys. I just finished replacing the globes in my AU Forte.
Just for the record, I didn't have to unplug the wiring to the dash. I just lowered the steering wheel to make some room and pulled the dash cluster out without disconnecting the loom.
The globes are only available as globe and holder from Ford. You won't find them at the servo or auto parts store (they're the size of a large grain of rice). The Ford part number is "ER 10B765 D" - you need two and they cost me ten bucks for the pair.
Cheers, Ed.
FOON is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2008, 05:12 PM   #11
HLC
Audi S3
they are t5's.
you can get them in LED form as well from autobarn etc, and they just replace the halogen in the globe holder itself.
HLC is offline   Reply With Quote Multi-Quote with this Post
