Old 11-03-2008, 04:04 PM   #31
b2tf
not here much anymore
b2tf's Avatar
Originally Posted by TE50 056
V8 Forte would have live axle. All AU XR8 sedans had IRS.
All AU utes (XL-XR8) had live axle.
All AU XR6HP had live axle, XR6 VCT had IRS.
Fairmont Ghia VCT/V8 had IRS all the rest have live axle.
So theoretically, to put an XR8 motor into a 6 cyl AU (as is thread starters intent), you would need the diff and tailshaft from either a V8 Forte or Fairmont. Ute stuff would obviously be no good.
2024 F150 XLT
Old 11-03-2008, 04:16 PM   #32
DJM83
Barra Turbo > V8
DJM83's Avatar
Yeah, not sure on whether the ute stuff is any good but i dont think it is.
But bits from a V8 Forte or Fairmont would do the trick
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
Old 11-03-2008, 04:30 PM   #33
b2tf
b2tf's Avatar
Ute stuff wouldnt be because tailshaft is longer, and leafs at the rear
2024 F150 XLT
Old 11-03-2008, 04:49 PM   #34
DJM83
Barra Turbo > V8
DJM83's Avatar
Yeah i knew about the length, but forgot about the old cart suspension :
Old 11-03-2008, 05:04 PM   #35
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
So basically i need to find a Wrecked V8 Forte or Fairmont to grab the Diff and Tailshaft out of ??
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2008, 05:07 PM   #36
DJM83
Barra Turbo > V8
DJM83's Avatar
Yep then you should be set to go
Old 11-03-2008, 05:08 PM   #37
b2tf
b2tf's Avatar
would make it a lot easier by the sounds of it, while youre there you can grab climate control, leather seats, ah bugger it just buy the whole car :
2024 F150 XLT
Old 11-03-2008, 05:37 PM   #38
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Ill see what FTG has .. ...
AU2PWR
Old 11-03-2008, 09:24 PM   #39
FS5
go to a wreckers and see if you can compare a i6 tail shaft to a v8 one.
take a tape measure and measure them and count the splines on the input shaft.
would save a lot of money seeing no one has a definate answer.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2008, 09:26 PM   #40
b2tf
b2tf's Avatar
I6 tailshaft cannot be used on a V8 engine.
2024 F150 XLT
Old 11-03-2008, 09:57 PM   #41
JoesAu
JoesAu's Avatar
yeah my oldman says they are different too
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2008, 10:00 PM   #42
LG
LG's Avatar
You can still use your existing diff, but just the tailshaft would need to be a V8 one, or have yours modified for around ~$200. You also have to get the same tailshaft with the right transmission. Manual & Automatic tailshafts are different lengths.
Ideally it would be better to slot in better diff gears and LSD, which you need to find from any Live Axle AU Sedan. If you want 3.23 or higher, you need the housing to go with it, and do a straight swap. But for the hassle, your better off just getting a place to rebuild your current diff with gears and LSD that you want for around $1500, as they would be brand new instead of a 2nd hand set for $650 that will most likely be shagged.
It sounds like a great deal, but personally all the effort and time required, I'd keep with the Forced plan.
Goodluck with it.
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2008, 10:23 PM   #43
FS5
whats the difference???
why not just swap the bell housing on your gearbox then????
will the v8 bellhosing bolt on the i6 box?
Old 11-03-2008, 10:52 PM   #44
FS5
maybe i should have posted it a bit better.
will a v8 bellhousing off a btr bolt onto an i6 btr ,or are they the same?
is the v8 box the same as they run in the i6?
i'm pretty much 99.9% sure an IRS diff centre will go into a live axel setup.a call to a reputable diffshop would sort this out .
Old 12-03-2008, 04:01 PM   #45
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
The Motor has a BTR Bolted up to it already ..
So The Motor , Diff and Box are Ok .. its just the Tailshaft that will be the problem
AU2PWR
Old 12-03-2008, 04:55 PM   #46
GK
Walking with God
GK's Avatar
Thumbs up
You'll get a tailshaft no worries.
Go for it Daniel, then you'll truly be able to spin em up, just like Habib! LOL!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 12-03-2008, 07:31 PM   #47
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Oh Sick Mate .. Ill be driving a FOV LIDR (<-- Say that in a Woggy Accent , you will know what i mean)
So , if anyone one knows of a Tailshaft , Send me a Message or Post here ..
AU2PWR
Old 12-03-2008, 08:01 PM   #48
private9
www.TUFFCARPARTS.com
private9's Avatar
^^^^^That's exactly how all of my wog mates refer to the bloody things! I'm possibly the only one in existence who doesn't!
You just missed out on a cheap as TT kit to suit a 5lt - Dave (Ghia5l) was selling it for $1200, just needed a fuel system. I think he said it's still pending payment, so you could always keep an eye on his FS thread.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2008, 08:41 PM   #49
RspecAU
BA GT-P Owner
RspecAU's Avatar
Try the Ford wrecker in Breaside he's pretty good with his prices
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
299.5 rwkw's 12.74 @108mph ON MT's
ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
RspecAU is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2008, 08:59 PM   #50
private9
private9's Avatar
REALLY good! Every time I've needed anything, they're always under.
Old 12-03-2008, 09:48 PM   #51
GK
Walking with God
GK's Avatar
Actually for a wog, it took me a while to get it! Five Litre! LOL!
Gee upon reflection, you must have a few wog mates to even make that gag connection, let alone post it! LOL!
GK
Now gone!
On LPG
Old 13-03-2008, 05:54 PM   #52
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
i have lots of wog mates - its melbourne George , Were all wogs !
Nah .. Alls good .. No Harm Intended , Wogs are Cool , Specially Oakleigh Wogs
Got the Motor Up on the Hoist today and Changed the Oil and Stuff in it , he also had some Pacemaker XR8 Headers .. So another Bonus .. this Guys shed is like Aladdins Cave , Tyres , Motors , Trucks - EVERYTHING !
AU2PWR
Old 13-03-2008, 06:17 PM   #53
blackers10
blackers10's Avatar
the live axle and IRS guts are the same
confirmed by a chap on here who owned a diff shop
id presume the tail shaft may be different tho due to the play in a live axle tailshaft (due to being able to move up and down)
also you cant use an EA diff as they had 25 instead of 28 splines like EB onward
On The Street Feature Winner Performance Ford Mag
See my car at:-www.aufalcon.com/blackers10
blackers10 is offline   Reply With Quote Multi-Quote with this Post
