16-03-2008, 01:02 AM | #1 | ||
GT-P #0336
Hey Guys
I have a few questions for you all. I had a reco auto fitted yesterday as mine was buggered. The hi-stall didn't look good either so it was removed (it's welded shut so it has to be sent off & checked) and a stock converter was fitted (for now). The battery was disconnected after this work was done so my question is do I need to re-flash? (car has the edit) Not sure whether it's necessary to do it. It drives fine. Really doesn't feel different other than there not being the stally in it. Am I suppose to re-flash it though or? The hi-stall is going to be sent off to be checked. It's the JMM3000. Depending on the report on it, I'm not sure whether to keep it or go with a TCE or Dominator 2800. Although I have heard that the JMM one is a re-badged and re-painted Dominator but whether that's right or not, I don't know. Any opinions on which stally to go with or should I stick with mine? The 3000 was matched to work with the cam that's in it. I doubt a 2800 will be much different will it? Is it true that if you fit a 2nd hand stall into your car, that there could be contamination from the previous auto? And if this is so, could something like that be the reason the car was constantly going into LHM? Because I've spoken to few people about this over the last couple of weeks and they've all pretty much said the same thing - that the 3000 should not have caused issues with LHM and are surprised it did before the edit sorted it out. Thanks Krissy.
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST ~Tuned By Bluepower Racing~ |
16-03-2008, 08:57 AM | #2 | |||
Smile
If the car idles properly and accelerates well then you don't have to worry about a retune. The car would not go into limp home mode from the contamination. I believe it is heat.In saying that a few AU'S on the forum run dominator converters and still got limp home mode. I would highly reccomend you speak to torque converter industries here in Seven hills. My converter is around 2500 to 2800 ..never had limp home and while its been 2 years at 320 dollars was a steal.Why pay more? I have a cooler and have since installed a transmission temperature gauge.My car actually got cooler going down the 1/4 mile. Cheers Stav
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
16-03-2008, 10:42 AM | #3 | ||
ive heard around the traps that OVER 3000 the comptuer goes oh crap the autos rooted and goes into LHM as it detects what IT thinks is slip in the box/converter
i have a 2800 and drive around in D all day long and it never has an issue but i know of another guy with a NL fairlane 4ltr that at the drags kept dropping into LHM as he stalled too high at the line im running a red diamond stall from QCES
On The Street Feature Winner Performance Ford Mag See my car at:-www.aufalcon.com/blackers10 Last edited by blackers10; 16-03-2008 at 10:54 AM. |
16-03-2008, 11:48 AM | #4 | ||
MADED.6
i have a 3000rpm stally and it will go to 3500rpm if i put the foot down heaps i dont no about off the line as it starts to spin at about 2500rpm as the tyres dont hold the road.
but i have never had limp home problems and actually thought the flasher would helps this. mine is flashed not tuned properly but it is flashed and they havent touched the shift points so once i get that done should be better. wat happened to ur auto was it just a stock auto? maybe u should get it one rebuilt with kevlar bands and stronger clutch packs? thats wat mine has and it also has stage 2 shift kit but wen driving normal shifts firm but not real harsh but when giving it to it shifts real nice. cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
16-03-2008, 11:56 AM | #5 | |||
16-03-2008, 01:16 PM | #6 | |||||
GT-P #0336
