11-03-2008, 12:00 PM | #1 | ||
hi all i have a 200 au2 xr6vct that has a bad idle problem and now it seems to have an issue were the revs go up and down on there own , not a lot but a couple of hundred revs and when is idling its quite obvious .its different to the rough idle problem though
i have replaced fuel filter ,air filter ,spark plugs and leads and its getting worse ..its like sitting in a mildly worked v8 thats how rough the idle is .when your at the back of the car you can a backfire/pop in the exhaust as well and when you start the car it beeps 3 times..like beep beep beep a pause then beep beep beep does that three times any ideas ,its still a great car and goes well : |
11-03-2008, 12:30 PM | #2 | |||
Walking with God
As for the rough idle, give the ISC a clean and see how that goes. It's a 5-10 minute job and often works wonders. Basically, the ISC controls the idle and if it's loaded with crud, it doesn't regulate idle correctly. Have a lookie here to see how to locate and clean it. Cleaning ISC http://www.fordforums.com.au/showpos...9&postcount=43 All the best with it. GK
11-03-2008, 01:35 PM | #3 | ||
hi mate thanks for that it beeps even when the tank is full every time i start it up ...opps forgot i did the ISC and it still rough
11-03-2008, 08:37 PM | #4 | |||
Walking with God
GK
11-03-2008, 08:51 PM | #5 | ||
Sly like a G6
How often does the VCT hardware play up? A wrecker told me once there was a valve or something that went... maybe the camshaft is in the opposite position to where it needs to be for idle, or moving around randomly??? What else affects idle? Power steering pressure sensor... aircon sensor?
And maybe the beeps are a general warning... I'm pretty sure that if I turn the ignition off or open the door with the headlights on I get the same 3 beeps. Might be worthwhile to get the PCM checked for DTC's.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
11-03-2008, 09:40 PM | #6 | ||
CRE.87V
yeh mate mine idles really bad up and down....cleaned isc, t/b and changed both gaskets....im stumpt on wat it is
11-03-2008, 11:08 PM | #7 | ||
Walking with God
Perhaps the ISC is faulty?
GK
12-03-2008, 06:31 AM | #8 | ||
yea is annoying aye ...........car also has a realy hot exhaust tip it gets so hot it pings as it cools down ..a bit frustrating .. : how do you check if the ISC is faulty and VCT unit ?
12-03-2008, 07:55 AM | #9 | |||
Walking with God
Can't help with the VCT unit sorry. I have Zero experience with VCT engines and my knowledge base is only slightly more than that! Surely others here could suggest something though. GK
12-03-2008, 09:06 PM | #10 | ||
as far as the beeping goes, are you starting the car with the door open? this will also beep like that, or if any door is open for that matter...how old are the spark plugs and leads? these may be worth checking as well, and also if you haven't already, give the throttle body a clean too
12-03-2008, 10:04 PM | #11 | |||
Walking with God
Cleaning Throttle Body http://www.fordforums.com.au/showpos...2&postcount=48 KUP (Keep us posted) GK
13-03-2008, 01:11 AM | #12 | ||
yeah, sorry about that, been a long week so far....
anyway, it may also be worth looking at the coil if you haven't done so and possibly check it for vacuum leaks too. apparently some of the smaller vacuum hoses towards the rear of the engine can crack, if you have a leak it will also cause rough idle issues |
13-03-2008, 08:19 AM | #13 | ||
sweet thanks for those ideas i will try all the above this weekend ...
14-03-2008, 09:50 AM | #14 | ||
You mentioned you thought your exhaust is getting very hot
Maybe your catalytic converter is blocked Cheers Autocade |
14-03-2008, 12:14 PM | #15 | ||
thanks will look at htat as well
does any one no how the vct works |
15-03-2008, 01:01 AM | #16 | ||
Ford lover
i fixed my rubbish idle with a new coil pack, leads and plugs. I too changed the pump, fuel filter, with no result.
18-03-2008, 02:00 PM | #17 | ||
a new coil pack aye will try that as i thinkl i have covered every thing else ...i hooked up a vachume guage and have been drivin around with that and the car seems fine acording to the guage .........just a damn rough idle :
18-03-2008, 11:06 PM | #18 | ||
ive noticed in my VCT that every 5 to 10 seconds when sitting at lights the revs will blip a tiny bit for a split second then go back to normal - can hear it thanks to the LOUD exhaust...but not a huge deal IMO.
2005 BF Falcon XT - 19" XR8 Alloys 2001 AUII Futura |
19-03-2008, 06:52 PM | #19 | ||
it blips when you have the AC on or off sanjay??
if i have the AC on it gives it self a slight rev every now and again(just waiting for a commo to think i want a race LOL)
19-03-2008, 09:48 PM | #20 | ||
ive had the air con on pretty much 100% of the time, will do some idling with the ac off and see if its any better. GKs tutorials on cleaning the ISC and throttle body dont look too difficult though, might give them a go.
19-03-2008, 09:52 PM | #21 | |||
not here much anymore
2024 F150 XLT
19-03-2008, 09:58 PM | #22 | ||
the symptom is more like this:
stop at traffic idles at about 900rpm every 10 - 30 seconds it will blip a tiny amount, to just under 1000rpm on the tacho, then back to normal. but i can hear it and if ive got my foot on the brake and sitting in D, i even feel a tiny jerk foward as if the car is trying to accelerate :p but yeah ive had the aircon on all the time because its been 37+ in adelaide...tempted to go and sit in some traffic right now but ive got uni work to do :p
19-03-2008, 10:00 PM | #23 | |||
2024 F150 XLT
