Old 15-04-2008, 10:30 AM   #1
ronwest
All Bran = Regular Member
Default Serpentine belt differences?
I'm replacing my radiator, thermostat and hoses (preventative maintenance) and while I'm doing that I'll replace the serpentine drive belt as well.
My local Ford does not have a belt in stock but I can get a Dayco belt locally from a gasket/belt supplier.
According to the supplier the Dayco cattledog lists belts "AU 98-02" and "AU XR6".
I'm guessing that the 'XR6' means VCT and the other is for non-VCTs?
Can someone confirm that VCT/nonVCT belts are different as he doesn't have the "XR6" one in stock and I'll save myself a trip.
ronwest is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2008, 02:19 PM   #2
Chippar
The Ancient Warrior
Chippar's Avatar
This is the information I received from Ford Spare parts.
AJK6 995 BELT,
(4.0L SOHC EFI 6 CYL (MP) OR
4.0L SOHC EFI 6 CYL LPG OR
4.0L SOHC EFI 6 CYL XR6 (HP) $46.00
AJK6 956 BELT,
4.0L SOHC EFI 6 CYL XR6 (VCT) $65.80
I'm not too sure on the current prices though and the DAYCO belts may even be cheaper.
Chippar is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2008, 07:45 PM   #3
ronwest
Originally Posted by chippitydip
AJK6 956 BELT,
Thanks for that.
So they are different. That looks to be the one... not that my local Ford had it anyway.
They quoted me $98.00 for it!
I see in Repco's flyer that they have a 20% discount off Dayco belts. I'll see if they have an AU VCT in stock (thanks for the part number; should be easier to cross reference).
Old 15-04-2008, 08:10 PM   #4
CliffM
XR6 Tragic
the VCT belt is slightly longer due to the Tickford sensor I believe, at least from memory...
CliffM is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2008, 08:29 PM   #5
nb_351
building the xe...
nb_351's Avatar
there is a vct idler, which makes the belt longer...
slowly but surely fixing up the king of the road
WANTED
P5 ltd/landau taillight centre panel
nb_351 is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2008, 09:30 PM   #6
b2tf
not here much anymore
b2tf's Avatar
VCT belt is longer to accomodate for cam idler pulley
2024 F150 XLT
Old 15-04-2008, 10:50 PM   #7
ronwest
Ah, ok.
That would be the one I pulled apart and greased (sounded dry)
Cheers...
Old 16-04-2008, 01:14 AM   #8
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
ok but how come the vct part no. is 956 when the other is 995, which is the lenght of the belt in mm's i believe. and the 6 is the no. of ribs.
Might wanna check the part numbers.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2008, 09:57 AM   #9
ronwest
Yes you're right, maybe the length is the other way round.
Thanks for pointing that out, I didn't notice and am going to ring Repco soon.
Old 16-04-2008, 11:34 AM   #10
ronwest
So, my local Repco has them (Dayco) in stock @ $45.59
VCT belt part # = 207694
Old 19-04-2008, 09:53 PM   #11
nb_351
building the xe...
nb_351's Avatar
they are a lot longer than 995...
i think theyre about 2100 long...
the 6 is right in regards to it being a 6pk belt though...
genuine numbers will sometimes use a totally unrelated set of numbers to name parts...
aftermarket comapnies like gates etc use the length and the style of belt, eg 6pk2100
WANTED
Old 19-04-2008, 11:43 PM   #12
b2tf
b2tf's Avatar
Bosch part number for VCT belt is 6PK2515 from memory, but I know I have one here that I ordered by accident (wanted one for the XR8 but got the VCT one by mistake). Brand new, $10 plus post if anyone wants it!
2024 F150 XLT
Old 20-04-2008, 12:19 PM   #13
5.0 ED
5.0 ED's Avatar
Well since 2515mm converted to inch's is 995, i think not that the numbers are random.
Old 20-04-2008, 10:40 PM   #14
nb_351
building the xe...
nb_351's Avatar
ahhh well done... wouldnt even have though about that...
and it makes esnse that theres about one inch difference in size, and that theyre motorcraft which is american based if im not mistaken...
learn something new everyday...
WANTED
