Old 23-04-2008, 10:10 PM   #1
302w
AU XR8
302w's Avatar
Default Diff Chatter After Rebuild
I just had the bearings, seals, oil, etc done on my LSD diff and the diff chatter is worse than before I had it fixed. Does it need a couple of days to settle down?
Cheers.
302w is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2008, 09:02 AM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
I wouldn"t have thought so, maybe 1/2 hour of driving around U turns and the like would have setled it down my guess would be wrong oil and or no additive
Originally Posted by Riksta
Old 24-04-2008, 09:44 AM   #3
howesy
howesy's Avatar
Cheers.
When mine was re-done it came up trumps. had it done at JMAC Diff & Gear in Arndell Park in Sydney. Couldn't be happier and its done around 35000km. Ran it in as per directions though(100km @60km/h then 500km@80km/h) just went on a couple of big long slow drives.
Can't beat a Windsor for sound and low down torque.
Liquid Silver Pursuit250
Custom gear and diff ratios
ECU
Exhaust
Crow Comp. Valve springs
Adjust. Rollers
Cold air
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2008, 10:51 AM   #4
RG
Back to Le Frenchy
RG's Avatar
I'm with you on that Whoosh. Go find a big empty car park and get the LSD working by doing some low speed tight figure 8's. If that doesn't work ask them if they used the right oil and the right additive.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2008, 11:33 AM   #5
Dark Horse
_Oo===oO_
Dark Horse's Avatar
I'd just make sure the right oil and additive has been used and give it a few k's. You'll just wear the LSD out doing figure eights in an empty car park - as was explained by the guys at Craft Diffs in Granville.
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2008, 11:39 AM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
No wonder we get so confused every Diff place has differant ideas :togo: we were told that low speed figure 8s and slow turns would bed the diff in, carnt see how it would ware it out as thats what there suppoesd to do I would have thought . who knows : : : :
P.S I would give Chriss at blupower a call, his dad is norhern diffs an he will put you straight
Old 24-04-2008, 12:03 PM   #7
Dark Horse
_Oo===oO_
Dark Horse's Avatar
That's what I thought until I asked those guys. : :
Old 24-04-2008, 12:22 PM   #8
RG
Back to Le Frenchy
RG's Avatar
Bloody diff shops. I've even been told by a bloke that used to work at Ford that is what to do (figure 8's) after you change the oil.
Old 25-04-2008, 06:59 PM   #9
302w
AU XR8
302w's Avatar
I was told the same thing, do figure 8's and donuts in a carpark, it's getting better but still clunks and chatters at low speed.
Diff place said they put in Penrite LIMSLIP 90 with Ford Motorsport addative and to give it a week, if it doesn't settle they will change the oil/addative to Castrol with Sturaco addative.
Old 25-04-2008, 10:37 PM   #10
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
How many figure 8's would you have to do before wearing out a the cones? me thinks a freaking lot, all though i will point out that you should not be doing them under load, when you put engine power down it pushes the cones outwards and increases the load, the should be nice slow figure 8's and yep its a correct procedure to bed in the cones.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
