Old 27-04-2008, 03:25 PM   #1
Built2redline
Default Problems with AUII XR8
hi guys i hope someone out there in ford land can shed some light on my problem..
i have a 2000 XR8 that has 113000ks it seems really sluggish, and when parking it in the garage i noticed that the exhaust is making some fluttering noises, and seems more muffled than usual.... its just not driving as usual and really needs to be pushed to move... any ideas?
i had a quick look under the car but cant see anything out of the ordinary, in fact the exahust (standard factory item) looks in really good condition, with no rust or holes..
Built2redline is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2008, 03:34 PM   #2
5L
[ 5L ]
5L's Avatar
maybe the catalyic convertors have collapsed (the honeycomb inside). i had this happen on my eb and it resulted in the car loosing alot of power. and the exhaust was making all funny noises.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2008, 04:05 PM   #3
b2tf
not here much anymore
b2tf's Avatar
I would be looking at cats too going by that description - push it round with your hand and it may make a rattling sound - if it does, its stuffed.
2024 F150 XLT
Old 27-04-2008, 04:06 PM   #4
Built2redline
damn hey!.... is there anyway of checking the cats before i head over to the exhaust shop?
Old 27-04-2008, 04:12 PM   #5
Built2redline
thanx b2tf... ill do that failing that ill go to the exhaust shup and get a full exhaust maybe? LOL
Old 27-04-2008, 04:30 PM   #6
Built2redline
what would have caused the cats to colapse?
the car had been stumbling a bit before this happened, i had replaced the fuel filter, sparkplugs, leads, and it didnt rectify the problem... so im thinking the ignition coils/packs are buggered.
would this have had a hand in buggering the cats?
Old 27-04-2008, 04:44 PM   #7
Peuty
Afterburner + skids =
Peuty's Avatar
From what I understand mate cats just collapse without any reason (other than wear and tear, of course)
Oo\===/oO
Old 27-04-2008, 05:40 PM   #8
Falcon SXR8
Falcon SXR8's Avatar
Try checking your spark plugs again too, my mate had the same problem he put new plugs in and it didn't change anything but when we checked again and I forget what plug it was. But as he was tightening the plug up beacuse it was in a funny spot he was craking the ceramic on the plug.
Anyway just an idea.
Had
EB XR8
AU XR8 220 (awsome car )
AU Fairmont
BA MK2 XR6 Turbo
Now
XDUB
Falcon SXR8 is online now   Reply With Quote Multi-Quote with this Post
Old 28-04-2008, 03:17 PM   #9
Built2redline
havent had a chance to have a look atthe cats, but ill check the sparkplugs as well thanks Falcon SXR8
Old 28-04-2008, 03:25 PM   #10
RG
Back to Le Frenchy
RG's Avatar
If the coil packs are still factory they will be pretty much stuffed, mine only lasted 85k. Oxygen sensors is another thing that should be replaced at those k's too. But by the sounds of it a/both cats have given up, I like your idea of a full new system though.
With the coil packs whatever you do don't get them from Ford, even MSD are half the price and a direct bolt up replacement.
Old 28-04-2008, 03:27 PM   #11
RG
Back to Le Frenchy
RG's Avatar
That'd be cyl.5, front of the engine passenger side.
What plugs did you use?
Old 28-04-2008, 03:38 PM   #12
Built2redline
ngk iridium IX, paid a small fortune for them too...
Old 28-04-2008, 03:40 PM   #13
james22
With da Warlords
james22's Avatar
Yep isn't number 5 a royal pain in the A lol
I keep breaking them... :-(
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2008, 03:45 PM   #14
RG
Back to Le Frenchy
RG's Avatar
Part# TR55IX. You will find that unless you closed them up that the gap is too big at 1.5. I have spoken to NGK recently and even thought they are the recommended part they are not gapped properly as the AU V8 needs a gap of 1.4. they also aren't real forthcoming with a safe way to regap iridium plugs so that helps....not.
They did help with the part# of cheaper non iridium plugs to suit but that's not of any help to you now.
Drives me nuts but so far I haven't broken one. The joy of using a plug socket and a shifter!
Old 28-04-2008, 05:17 PM   #15
Built2redline
sorry russell, i completely missed this post.
yeah the coil packs are still the factory originals, so ill replace those too while im spending some time/money on this car. you say MSD coils? would repco stock them?
also where is the oxygen sensor in this engine?..
the car was getting an average of 400ks to a tank is this normal or not!
thanx for all the help BTW guys :sm_headba
Old 28-04-2008, 05:21 PM   #16
5L
[ 5L ]
5L's Avatar
o2 senosr is on the exhaust manifold, there is one on both sides so you will have to replace both.
im going to be replacing mine soon, car idles like is got a decent sized cam in there. drives me nuts.
Old 28-04-2008, 06:08 PM   #17
RG
Back to Le Frenchy
RG's Avatar
Repco will be able to get them. You are after Part# MSD8241. I recntly paid $145ea. You need the two obviously. Might be a good time to do leads too, if so get on to a member here BOTTLEDUP as he will supply you with a set of MSD leads for $200 shipped to your door. Best value lead out there.
As said above the sensors are bolted in the exhaust just before the cats and they are around the $100 mark each.
Old 28-04-2008, 06:36 PM   #18
Built2redline
so much talk about her i may as well post a pic
Old 28-04-2008, 06:43 PM   #19
RG
Back to Le Frenchy
RG's Avatar
Nice, but those orange side repeaters would look better if they were clear AUIII ones.
Old 28-04-2008, 06:47 PM   #20
Built2redline
mmmmmmm i think this site is going to be ............expensive LOL
i do agree that the clear repeaters would look nicer.... its amazing i had never noticed them before
Old 28-04-2008, 07:22 PM   #21
richo77
richo77's Avatar
a rattle started in my (once factory) exhaust it ended up being the flange between the header and exhaust coming loose, held on with a tiny spot weld.
just take it to a reputable place, they'll put it on a hoist for you and fix it there and then if its that.
cheers
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2008, 07:26 PM   #22
RG
Back to Le Frenchy
RG's Avatar
$30 odd for the pair from Ford spares.
