03-05-2008, 09:23 PM | #1 | ||
www.TUFFCARPARTS.com
Hi All,
As the subject heading says, just wondering if anyone has an airbag tool lying around that they've used, and will never use again that they'd like to sell? None of my local places (Autobarn, Repco & Supercheap) stock it, so thought I'd ask here. Thanks, Justin. |
03-05-2008, 10:10 PM | #2 | ||
Now Fordless
If its just a regular torx bit Repco should have it. I've got there set in my toolbox at work.
Any other tool place should be able to supply one. Even Bunnings might be the go. |
03-05-2008, 10:20 PM | #3 | ||
Nah, it's a 5 sided Torx bit, which nobody seems to carry!
03-05-2008, 10:33 PM | #4 | ||
quarter pane
If you meant the 2 security bolts on the side, drill the centre "pin" out with a carbon bit and tap a small 6 sided Torx bit into it to unscrew. They aren't in very tight and come out easily. Then replace them with some decent Allen bolts.
04-05-2008, 12:30 AM | #5 | ||
This mob sell them for $16 each although they show a pic of a six point instaed of a 5 point. http://krewtools.com.au/index.php?
regards Blue |
04-05-2008, 10:10 AM | #6 | |||
I just put an order in at my local Repco for a set of bits, 67 bits, $40. It has the required TS-Plus bits. There from SP Tools
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
04-05-2008, 05:12 PM | #7 | ||
Bursons supplied them off the shelf very cheap, and I dont know about them being loose mine were as tight as buggery
Can't beat a Windsor for sound and low down torque. Liquid Silver Pursuit250 Custom gear and diff ratios ECU Exhaust Crow Comp. Valve springs Adjust. Rollers Cold air |
04-05-2008, 07:43 PM | #8 | ||
MADED.6
yeah bursons stock them justin.
cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
04-05-2008, 07:45 PM | #9 | ||
Thanks for the advice guys, Bursons it is!
Still, if anyone does have one that they'd like to sell, and they can post, let me know, so I can save a bit of time! Thanks, Justin. |
