Tuned @ Pitlane Frankston
well it didnt quite implode, but i was driving along yesterday down wellington road near clayton uni, and the car started hesitating badly, so i dropped it back to neutral, and it stalled. i pulled over, switched to petrol to see whether or not there was somethng wrong with the gas, but there wasn't. it still didn't fire, just cranked and compression locked.
the engine is in an ed fairmont, and uses a dizzy instead of the coilpack. so anyway, today we went back and tried to figure out what had happened. it wasn't the coil because there was spark, and it wasn't fuel cos there was plenty coming through. i took the dizzy out, and had a look down into the engine, and saw that it was pretty mangled. we figured out that whatever the shaft is that the dizzy connects to inside the block, has been stripped or bent, or something, causing the starting problems. anyone got any more info for me as to whats inside that bit, or a diagram or something? thanks guys
you have stripped you auxillary shaft. So your oil pump must have siezed which stops the auxillary shaft from turning thus stripping all the teeth.
Big job to repair$$$$, probably drop the sump and have a better look, broken timing chain guide can cause this or bits of foreign metal filings in the sump oil. |
wow, this sucks.
i just got it towed to the workshop, dad's gunna take the engine out and check everything out. it wasn't low on oil, so i'll check the timing guide and stuff. i wish this sorta stuff didn't happen to me :(
www.TUFFCARPARTS.com
Bad luck mate.
Since you're gonna pull the engine anyway, it would probably be cheaper and safer, to grab another low km AU long motor and swap that in. Just get it without accessories to save some bucks. They seem to be getting pretty cheap these days, and I've seen them as low as $300 with apparently good kms.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
Pushrodosaurus Rex
ive also seen v8 windsors from aus sell for 500 complete......
better than a 6 pot ![]() |
#6 | |||
Please do, it's always soooo entertaining ![]()
#7 | ||||
Back to Le Frenchy
Yay, our smiley's dance in unison^^^^!
I admit it, I am secretly a wheezer V8 lover - there's something just right with their combination of a perfect sound and lack of power!!!
#9 | ||||
Back to Le Frenchy
Problem solved! ![]()
Sly like a G6
Perfect sound? A wheezer sounds nothing like a 3.8 litre MkII Jag!
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
Pushrodosaurus Rex
hahaha look at the mess i created!
Ok guys,
got the car back from dad, he replaced the timing chain, aux gear, dizzy shaft, various other things, and chucked it back in. running very smooth now and looking good. with the tow (90km's) it cost just under $500 for everything, so i'm happy.
#13 | ||
Narooma blue XR8 ute
good to see you got it all sorted and without spending to much
#14 | |||
#15 | |||
Wanting a sprint!
Hey Thats not nice, Damn i hate biting my tongue. ![]() Good to see you got it all sorted out shuresm58 and at good deal.
On track for mint turbo falcon |
