Formally ED I6
Heres a couple of pics of the BBM on my ED where the manifold has hit the bonnet
![]() Has anyone had the same thing happen???
Daily driver 98' AU 349ci Fairmont Ghia on LPG --------------------------- Other 93' ED 5spd 4.0L NA Fairmont 13.75 @ 101mph |
hibernating
is your passenger side engine mount ok? maybe the engine is lifting up when you rev?
Formally ED I6
How do I check that?
It rocks a little in neutral, but all 4.0L do.
hibernating
check if the engine moves much when you give it a rev.. or have alook under the car check if the rubber on the engine mounts is ok and not broken. i wouldn't think that it would usually hit the bonnet otherwise
PM me if you want
Mine is clear, hasnt hit the bonnet at all, but I did have a broken passenger engine mount when I had my engine out ages ago, and is replaced, so neb may be on the right track i reckon.
Formally ED I6
Engine was out and fully rebuilt in November, so I'm hoping its not a broken engine mount, too wet today to get under the car and check.
I should note though the manifold was hitting the bonnet at the drag strip I assume during the burnout so maybe its just one of those things.
Would say its almost certainly a busted engine mount.
They aren't strong, I've broken several of them. I broke one once when I missed a 2nd-3rd shift. Engine tried to climb out of the engine bay and rocker cover hit the bonnet putting a nice big dent in it. Stupid crap. Only solution is to limit how much they can stretch. - John |
RIP...
Engine mount.
Rick.
. Oval Everywhere... |
put ya handbrake on, in gear and stall up the clutch get someone to watch it lift up
EF Falcon Sedan 5.0 auto with IRS "the man that crashs AFF" |
if you nail it in second, does the gear shifter move from the left to the right??? another sign the engine mount is cactus
Powered by Rollin Motorsport Turbo Barra ED 4L
02/90 EA II Fairmont
my engine mounts are fine (new even) and my gear shifter moves a fair bit...
211RWKW EA |
#12 | |||
Formally ED I6
#13 | ||
v8 Bulge :P
#14 | ||
come join me
Engine mount is broken or needs replacing.
#15 | ||
Formally ED I6
Thanks for the replies people, I will get under the car and check as soon as it isn't so wet around the car
