Old 18-04-2006, 01:34 PM   #31
OZFORDAU
OZFORDAU's Avatar
Default Why?
Originally Posted by Bluedriver
yer price is good but I wouldn't recommend them.
Why wouldn't you recommend them? What's wrong with them?
Simon
OZFORDAU is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2006, 01:59 PM   #32
Au2falcons
Winter all year round
Just a bit of my advice from my experience. I've got the factory fitted XR6 rims on my AU. When my tyres were replaced by bobjane the alignment was also adjusted. My steering wheel was off centre & the car pulled left afterwards.
I was ИИИИed with bobjane & didn't want them to touch the car again so I went to pedders, immediately they said you need a castor/camber kit! $300.
Couldn't afford it at the time so I waited a month or so and booked it in with a local (small business) steering place to get the kit done. When they started checking the car out the guy said "who told you it needs a kit?". Turns out it didn't need one.
They guy explained that the geometry of the tyres was different to the originals which was why the steering was off centre & the IRS alligment was totally screwed which is why it was pulling. (Funny how I paid for a 4 wheel alignment at bobjane).
He also said you only need the kit when lowering the car because major adjusment to camber is required, in my case he inserted an 2mm shim on one side and it corrected the camber.
My suggestion would be to stick to the smaller companies who have been around for 10 years or more, these larger companies just don't cut it, I went back to bobjane to stick it too them, they didn't even know what the shims were. Get your car lowered, and get the kit done afterwards (if required) and you should be a happy camper.
Some people drive sports cars on the weekend....I drive my AU! It's not what you drive...it's how you enjoy it.
Recommend trading with Mechan1k, Offyaguts, EDMONTY, PhantomXR8, HOTC2R, Partie & JC
Au2falcons is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2006, 05:23 PM   #33
OZFORDAU
OZFORDAU's Avatar
Post Just got it home!
The camber/castor kit has just been installed! It's much better! Steering has also inproved! But........THEY SCRACTHED ONE OF MY RIMS! NOT HAPPY JANE....They reckon it wasn't them as they take good care! The area manager did the job on my car i was told so he would've told me if anything had happen to my wheels! There going to ask around the work shop to see if anyone knows anything!
Simon : : : : : :
PS: And yes i did inspect them befor i left......
Old 19-04-2006, 08:37 PM   #34
The Dok
The Dok's Avatar
Simon : : : : : :
Sorry to hear that e I still think you ИИИИed your money into the wind, hell, mine's been lowered @2" on the front (@2 1/2 years ago) & no camber/castor kit required, also no tyre wear, none-zip-zilch-nudda. Had the alignment checked @4 weeks ago.......no problems. I thought these kits were for older cars up to EL, I've not heard of them being "necessary" on AU's.
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2006, 09:05 PM   #35
GK
Walking with God
GK's Avatar
I guess Simon has bought some peace of mind, except for the scratch on the rim of course!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 20-04-2006, 09:37 AM   #36
FTE217
T3/Sprint8
FTE217's Avatar
Yes you are right and wrong.
My car also doesn't have them due to going to guys I know in the game who are very good aligners but this also goes to the build of the car.
Some are straight and some are not !
I do have some slight inside edge wear at my drivers side front but thats probably from hitting some pot holes unfortunately and not getting alignment check since.
I used to get alignments done every 3mths, rotation and perfect wear.
I suppose it comes to how pedantic you are.
There is also the case's that many aligner's without experience find the easiest way to get correct results is using camber/castor kits all the time.
This is why you go from one place and the other and get conflicting remidies !
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
Old 20-04-2006, 11:44 AM   #37
Autocade
Sorry to hear that e I still think you ????ed your money into the wind, hell, mine's been lowered @2" on the front (@2 1/2 years ago) & no camber/castor kit required, also no tyre wear, none-zip-zilch-nudda. Had the alignment checked @4 weeks ago.......no problems. I thought these kits were for older cars up to EL, I've not heard of them being "necessary" on AU's.
The Dok either you are lucky or I am very unlucky
My understanding is that AU does not allow adjustment for camber or castor(except for T series which have a different upper control arm bracket to allow for camber adjustment)
I had to fit a kit @ 28000 Ks on AU 2 XR6 with 17' due to the car running excesive negative camber and wiping out tyres prematurely
Ford weazled out when I tried for a warranty claim
Perhaps they are not all the same
Autocade is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2006, 12:25 PM   #38
The Dok
The Dok's Avatar
No luck involved really. When I rebuilt this car @3 yrs ago (was written off, not by me), I was conscious of front end dramas (from my EF), so paid careful attention to the whole set-up (easier when the crossmember/suspension is out of it) replaced the 2 lwr ball joints with decent brand, swaybar bushes (rubber), springs replaced with (reset Road Kings) 17" Tickford rims & brand new tyres. @30000 k's & 3 alignments (1 rotation 4 weeks ago) alignment check (didn't require adjustment) no problems. I have a few mates in the wrecking business so I had access to very good advice about the AU & what to look out for. _2:
Removed by laminge
Old 20-04-2006, 04:57 PM   #39
Autocade
Sounds like you have been down this track before as have I with an EL
Most AUs would be unable to compare to your well engineered setup.
IMO if you have any issues a $300 FEA kit is cheap insurance against wiping out a set of tyres prematurely
Once installed most decent places with modern equipment are able to set it up perfectly.
Old 21-04-2006, 09:31 PM   #40
phildee
phildee's Avatar
Rather than starting a new thread, have just ordered some King's Low's and a set of Monroe GT Gas, should I get the alignment done straight after I fit the springs/shocks or wait for the springs to settle?
Cheers, Phil
phildee is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2006, 10:17 PM   #41
GK
Walking with God
GK's Avatar
Cheers, Phil
I would say wait a week or so, but that's more of an opinion and an educated guess rather than based upon hard facts and experience!
As a few said to Simon earlier in this thread, a few week's driving isn't going to stuff the tyres, and his were new weren't they? You're not replacing tyres are you? If not, then I wouldn't think waiting a few weeks would hurt!
It stands to reason to let the new set up settle, but I could be wrong. Have been wrong before, will be wrong again! LOL!
That's my 2 bob's worth.
GK out!
Now gone!
On LPG
Old 21-04-2006, 11:28 PM   #42
phildee
phildee's Avatar
GK out!
I figure its going to be better being out for a couple weeks than correcting it straight after lowering then potentially being out a little after that if it settles much. But ive never lowered a car before so im not sure. And nope, no new tyres yet
Old 22-04-2006, 12:20 AM   #43
GK
Walking with God
GK's Avatar
Give it a few weeks. I think your rationale makes good sense. Better being out for 2 weeks now, than out later for a long time.
GK
Now gone!
On LPG
Old 24-10-2008, 07:25 PM   #44
Hords
Treasure your balls?
Hords's Avatar
Give Pedders in Footscray a big miss! After $1500 worth of work done 18 months ago I promptly returned after a few k as my steering wheel was off centre. Can't be they told me. The mechanic was peeved and took it for a drive (more like fang). He reluctantly agreed and then fixed it. A month later whilst doing an oil change I noticed a large bolt on each side had the nut on only finger tight. Blasted 'em and the manager blamed a past employee they weren't happy with and had to relieve. Right at that moment the mechanic walked into the sales desk area. Let 'em have it then.
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
