20-07-2005, 12:21 PM | #1 | ||
Custom User Title
Ok, I don't know why, but my handbrake has gone floppy. It just mjoves in and out freely, when you pullit out it does nothing, the button dones nothing, it's just a pain in the neck because whoever invented canberra decided to make the roads as not flat as possible, and there is only so much weight that the box can hold and only so many rocks that can be found on the side of the road...so here's the question...What's gone wrong and how do I fix it, and how do I fix it? It's really ****ing me off.
20-07-2005, 12:24 PM | #2 | ||
likes falcon's
get cable adjusted and DONT THRASH IT !! lol
www.carhubsales.com.au |
20-07-2005, 02:47 PM | #3 | ||
The Guy You Love To Hate
Do a side mount (A.K.A NORMAL!) handbrake conversion.
NO wait, make it a HYDRAULIC HANDBRAKE conversion. mmmm And get a manual in there too. Then start getting some handbrake entries happening for your drifts. Thats wat i would do anyway... |
20-07-2005, 03:57 PM | #4 | ||
Two > One
The car is manual already. Sounds like you have a stretched/broken cable. FIX IT.
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
20-07-2005, 04:35 PM | #5 | ||
I was going to say something like "because umbrellas don't go very fast" but then I read your problem description. Sounds like something on the lever itself has broken with symptoms like that. Either that or a cable has broken.
20-07-2005, 04:56 PM | #6 | |||
hibernating
20-07-2005, 05:47 PM | #7 | |||
windsor user
20-07-2005, 06:03 PM | #8 | ||
Custom User Title
Alllmost had an accident today, car was parked on a slope (the whole carpark is bodgy), get into the car, clutch in...rooool.. : almost hit some person in a camy behind me. but anyway...what is involved in replacing the cable?
20-07-2005, 06:04 PM | #9 | ||
Hmmm Gold!!!
is there a way of doing the conversion? id be interested in doing it.. ive never really looked at the setup, there would have to be a mounting bracked welded onto the center consol wouldnt there? and there doesnt seem to be the room in the early e series between the seat and the consol to put on there anyway...
bender
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
20-07-2005, 07:00 PM | #10 | ||
To replace the cable you remove the plastic shroud around the handbrake lever (two phillips head screws) then unbolt the lever (3 13mm bolts, 1 up near handle, 2 on firewall under carpet) Then outside the car 3 10/11mm nuts holding cover plate (in engine bay on firewall), then unclip the cable below drivers seat, and also the clip holding outer cable in chassis. Remove cable and handle through inside the car. Pretty straight forward to remove the cable from the handle assembly once out of the car, and replace with new cable, installation is the reverse.
Hope that helps.
Proud Owner of 06' TTG |
20-07-2005, 07:22 PM | #11 | ||
Our handbrakes aren't THAT bad! Just think of Torana "hand" brakes...
20-07-2005, 07:41 PM | #12 | |||
Parts bin special
I certainly prefer our handbrakes over the one in dad's 89' Rodeo. The button works a lot better than the old "twist and turn" style. Add to the fact that in the rodeo, the handbrake hardly holds it on a hill, and the fact the handbrake light is always on, even when the handbrake is off! Gee, that ute is a POS
20-07-2005, 07:51 PM | #13 | ||
V8 Powaah
Consider yourselves lucky. Umbrella style handbrakes absolutley flog the the foot handbrake i've got in the Avalon.
Not only do i forget it 3/4 of the time, it also only works when pushed to the final 2 notches, it gets in the way of the footrest when parked, useless for hill starts and the like. But most importantly it destroys any hope of doing a handbrake turn.
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
20-07-2005, 08:11 PM | #14 | ||
Former E-Series Member
The umbrella is not the best, and I think the extra long travel of the cable contributes to its awkward operation. I've used a foot operated park brake once on a Merc and it definitely is weird. Audi have taken the concept further with the new A6 and a complex button operated electronic park brake that deactives when the car is put in drive.
20-07-2005, 08:36 PM | #15 | ||
yeah the new landrovers have a button on the center console that you press to engage and release the handbrake. It's all automated. It's gay.
20-07-2005, 09:17 PM | #16 | |||
BBQ gas User
They are quite easy to replace and i have no trouble getting them to hold on hills. But damn, i miss the lack of handbrakies in wet weather / gravel. I have a mate with a bench seat AU with a foot operated hand brake and he says it works a treat apart from he has to be careful not to rest his foot on it or pretend its a clutch!
1974 TC Cortina Sedan (sold); 1974 TC Cortina Wagon (sold); 1987 XF Fairmont Ghia (flooded); 1985 XF Ute 351 T5 (sold); 1995 EF Falcon (sold); 1999 Pajero & 2007 Aurion |
20-07-2005, 09:25 PM | #17 | |||||
No longer driving a Ford.
For those of you who have never seen it, it's basically another pedal on the floor, slightly more towards the trans tunnel then the clutch pedal would be. That engages the "handbrake", then there is release on the dash next to the choke. Weird indeed!
20-07-2005, 11:03 PM | #18 | |||
Parts bin special
One thing I do like about the umbrella style handbrake is when sometimes I have had tools in the car try to rip on the handbrake while I was driving. They reach down for the seat before realising, the handbrake isn't there! By that time I'm ready for them so if they try to rip on the umbrella handbrake, I can stop them before they get their hand to it.
21-07-2005, 09:41 AM | #19 | ||
The Torana one sounds the same as the Avalon/Lexus/Merc/etc one. They call them foot operated park brakes.
21-07-2005, 06:23 PM | #20 | ||||
21-07-2005, 06:26 PM | #21 | |||
meow
As of 5 minutes ago:
21-07-2005, 06:26 PM | #22 | ||
hibernating
I have a question... has anyone ever done a handbrakie with an umbrella style handbrake in e-series... is it possible to get it to work good enough to do it?
22-07-2005, 11:04 PM | #23 | |||
ooga-lagga-ligga-lagga
i had a HZ (please dont tease me), but the handbrakes in them are the normal style (yes good) on the drivers right hand side, but when you pull it up it stays on, until you let it go back down a bit and then reapply it. This made it very hard to do handbrakeys, i forgot one day and as it just stayed on, i couldnt release it in time and hit a kerb, it was wet too... pretty funny thinkin back to that moment of panic."yeh gonna do a sik handbrakey, skid AHHHHHH what to do BANG grrrrrrr |
23-07-2005, 11:40 AM | #24 | ||
The cables do break, EA's are getting older you know
But $30 at the wreckers for the whole assembly, including the handle assembly and about half an hours work and it's fixed. no big deal When you get the assembly from a wrecker it sort of explains itself as to how it fits. Clean it and grease it before you put the new one in and it'll last longer The only thing is you'll have to jack the car up to swap the cable underneath |
23-07-2005, 11:46 AM | #25 | |||
windsor user
there is no way of knowing how long it will last before snapping again |
23-07-2005, 01:59 PM | #26 | ||
yeah i think a new cable is less than $30 anyway, why would you need a whole new (old) assembly.
Have you fixed it yet slection ? |
23-07-2005, 02:24 PM | #27 | ||
Custom User Title
Nah, i'm going to sydney in a few days to get some parts off an EA Ghia, i'll grab the handbrake off that
