20-01-2009, 10:34 AM | #1 | ||
My car has developed a squeek coming from the fan belt area. I replaced the fan belt, two idler pulleys and the tensioner pully. Still I get the squeek, squeek, squeek. Several people have looked at it (even with the stethascope thing) and they all say its coming from there somewhere.
I took it to an aircon guy and he told me to turn the aircon on and off a couple of times and he said its not the aircon. Any ideas ? its an XR8 ser 111 |
20-01-2009, 12:40 PM | #2 | ||
Power steering pump ?
Mine seems a bit noisy like a bearing squeal that comes and goes. |
20-01-2009, 12:55 PM | #3 | ||
Monsoon SIII XR8 220
I have a squeak which I finally tracked down by trial and error to the air-con compressor, I just spray a little wd40 into the pulley/electric clutch and it goes away for a few months.
Cheers, Simon |
20-01-2009, 05:16 PM | #4 | ||
Thanks XRLNT-8. I will give it a spray tonight. Did it stop squeeking when the aircon was turned off ?
20-01-2009, 11:04 PM | #5 | ||
Hi Bill,
The squeak is there while aircon is on or off. There is a small gap between the pulley and clutch which is where I spray and instantly the squeak goes. Good luck, Simon |
