Old 28-01-2009, 07:08 PM   #1
aufairmontghia
XR6
aufairmontghia's Avatar
Default Oil Pressure Gauge inaccurate????
Hi All
Is anyone out there with an oil pressure gauge on their dash eg. fairmont, Ghia, XR etc... finding the reading accurate or all over the place?????
aufairmontghia is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2009, 07:45 PM   #2
frank#2
I checked mine against a mechanical guage and found it to be dead on.
frank#2 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2009, 08:36 PM   #3
Cam
Stroking it...
Cam's Avatar
From what I have read, on the AU's the oil pressure is either on or off, and wont give accurate readings of any pressure drops etc For example in my AU no matter how i am driving (hammering it or idle) it always reads the same
Thus why i am looking at putting in a decent electronic gauge
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2009, 09:19 PM   #4
aufairmontghia
XR6
Guys
My gauge seems to go up & down with RPM's????
Where does you needle sit when driving???
Old 29-01-2009, 05:24 PM   #5
Cam
Stroking it...
Cam's Avatar
Is it an AUI?
I believe there was a fault with earthing in the AUI's and this caused the described issue, Surely someone else can confirm...
Usually AU oil pressure guages dont move, really accurate things... Unless of course there is an isue with the sender etc
Had: 347ci AU
Old 29-01-2009, 06:00 PM   #6
Night
From what I have been told the series 1 AU have a real oil pressure gauge so it should be pretty right but series 2 and 3 have a dummy gauge and it won't give you the actual oil pressure, just a normal reading.
Night is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2009, 06:20 PM   #7
aufairmontghia
XR6
AU S1 Ghia 4 sure...
Drove home from work tonight in 44 degree heat & about a km from home waiting for the lights. The oil pressure dropped in the red on the gauge & the oil warning light came on...
Didn't know what to think as I only changed new oil & filter on Monday????
Any ideas what could be wrong???
Gauge, sender, oil pump, no idea?????
Help..... :
Old 29-01-2009, 06:31 PM   #8
Cam
Stroking it...
Cam's Avatar
What Viscosity oil did you use?
Although it could be the sender, try disconnecting the wire from the sender, and clean any crap off it, otherwise replace the sender, or hook up a mechanical gauge and make sure oil pressure is ok, in which case it is the sender, otherwise could be the pump, not sure how often they die on I6's?
Had: 347ci AU
Old 29-01-2009, 06:42 PM   #9
aufairmontghia
XR6
Thanks
Castrol Modern engine 10-30w as recommended & a Ryco filter.
Where is the sender & oil pump located??? I'll try cleaning the contact on the sender...
Old 29-01-2009, 08:50 PM   #10
brad`
The Monty
brad`'s Avatar
well mine stays between (0-7) i think the guage its and it usnally goes about 3/4 unless i hammer it and it creeps up to 5.
cant help u out with much else haha
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2009, 09:24 PM   #11
blackers10
blackers10's Avatar
ok guys
the series 1 AUs have a REAL oil pressure guage
the S2-3 have on or off ones
the AU1's have inadequate grounding to the engine block so the sensor reads all wonky somtimes (mine does it usually with the aircon on at the lights)
if you run a new big fat cable from the Neg battery terminal to a bolt on the engine block it will be all fixed
On The Street Feature Winner Performance Ford Mag
See my car at:-www.aufalcon.com/blackers10
blackers10 is offline   Reply With Quote Multi-Quote with this Post
