ORSM FORD CRUSIERS
hey ALL
i've got a couple of questions to ask. I have a EB series 2 I6 with stock brakes that shudder i want to up grade instead of machining again. 1. i want to up grade my brakes but in a simple way. ive been told that V8 brake boosters work better than stock I6 ones. is this true? 2. what are the cost of slotted rotors? and are they much better? 3. is it possible to easly adapt later model brakes to my car eg:AU? thanks heaps. :1syellow1
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
likes falcon's
i would think slotted rotors, and good pads would be cheapest and easiest upgrade
www.carhubsales.com.au |
White Lightning
if you were lucky you could find an el gt set but youd need rims to fit the huge rotors in. go slotted [and crossdrilled if you want] and get some good pads. it will cost you a fair bit to fit AU brakes which arent any bigger i dont think? and yes the v8 boosters are a bit better.
AUII/III had a Twin-Piston Setup up front. I'm selling my ones, if you are interested.
To further make the conversion to the twin-piston setup, you will also need: - Aftermarket Swaybar (& Possibly Swaybar Mounting Points) - 16" Wheels or Greater - Lower Control Arms - Uprights Theres a bit involved, but slotted rotors and different pads, would be the cheap route, and would still be pretty good on the street. Although, my AUIII did pull up a fair bit harder compared to my mates AUI, which has the same brakes as you.
Custom user title
the lower control arms from an au wont fit in an eb.... so that turfs any idea out the window of using the au set up...
Yeah whole K frame is needed.
EF Falcon Sedan 5.0 auto with IRS "the man that crashs AFF" |
#7 | |||
The one and only
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
ORSM FORD CRUSIERS
thanks guys i think i will just go the slotted rotors with some nice pads and a v8 brake booster.
Custom user title
If u use au k-frame then u need au sterring rack, and then the stering coupling wont fit, yada yada yada.. the list goes on. Id go the sloted rotors and good pads
beep beep
cebco brakes to an upgraded full package for e-series. While it isn't 'cheap' it is complete.
For $2700 + fitting (all the parts included, you could do it yourself) you get PBR twin piston calipers, pads, braided lines and sizable 330mm discs (also includes brake fluid and other things I haven't mentioned. If you are serious about proper performance braking they also do a 4 pistion AP Racing kit for $3995. Both of these are front only kits which do 80% of your braking capacity anyway. Good pads, braided lines and clean fluid are all that are really required until you start track racing, and even then upgrading to some grooved and vented discs at the rear will be 99% of your needs. www.cebcobrakes.com.au 40-42 Mills Road Braeside 3195, Vic, Australia Phone: 1300 55 66 40 Fax: (03) 8586 2510 Email: john@cebcobrakes.com.au
Nothing to see here, move along, move along... |
#11 | |||
Dont get the rears though! If you get the rears you lose the ability for getting cheap burnout rubber! It sucks!
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
#12 | |||
beep beep
AHAHAHA good call ![]()
#13 | |||
The one and only
Parawolf - thanks for the info.
#14 | |||
I miss having a spare set of 14's to go on! :SaiyanSmi
#15 | ||
ORSM FORD CRUSIERS
nah i don't plan on spending that much im omly a student with no money!!
but the apeal of nice huge stompa brakes is damn nice. i think i will just stay cheap as for the moment.
