03-02-2009, 09:29 PM | #1 | ||
Has caught the bug...
Hey everyone I was reading the tech article on painting my calipers, and i'm planning to get started tomorrow but this step here I was a bit confused about....
"Some cars like the AU come with a black disc in between the wheel and the hub take that off as it gets in the way and I would leave it off but that is up to you" Can anyone show me which part this is with a description or picture please, I dont want to be taking parts off unless i'm sure Any help would be appreciated |
03-02-2009, 09:34 PM | #2 | |||
Resident AFF detailer
03-02-2009, 10:07 PM | #3 | ||
Ah ok, dont think mine ever had them.....
Next question how hard is it to get the calipers off and on? Is it worth taking them off for a better finish or just save the time and keep them on? |
03-02-2009, 10:10 PM | #4 | ||
U MAD?
Keep them on. Just mask around it with newspaper etc. I've done it before. The finish was mint and did not need to take them off. Unless you're a pro, leave em on. The important thing is that you clean them properly before painting.
Miami Heat 2010-2011 NBA Champions: C - Zydrunas Ilgauskas PF - Chris Bosh SF - Lebron James SF - Dwyane Wade PG - Mario Chalmers C - Erick Dampier PF - Udonis Haslem SF - James Jones SG - Mike Miller PG - Carlos Arroyo C - Joel Anthony C - Dexter Pittman C - Jamaal Magloire PF - Juwan Howard SG - Eddie House |
03-02-2009, 10:52 PM | #5 | ||
cheers
04-02-2009, 07:47 PM | #6 | ||
so did you give it a go??
04-02-2009, 08:27 PM | #7 | ||
Yeah this was the first one
wasnt too bad apart from a bit of spray on the discs which was easily cleaned off |
04-02-2009, 09:42 PM | #8 | |||
Sales Representative
04-02-2009, 09:44 PM | #9 | |||
AU DIE HARD
Looks good now just grab some silver and do the rotor center as well
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... .................................................. Quote:
05-02-2009, 12:14 AM | #10 | ||
I was hoping for a bit darker too, but hey what can you do
Yeah that will be next, one job at a time :P |
05-02-2009, 07:00 AM | #11 | ||
Neglecting the P250
That looks like a nice job. Did you actually take the calipers off the rotors or do them in-situ? My approach was to do the calipers while hanging off the brake line (only two bolts to get the calipers off) and then slide the rotor off and give that a hit (in black, or your preferred colour) while I was at it. Makes for a much better finish.
Blue Power Racing Developments
Great work and not a bad bloke ;) AUIII XR8 Pursuit 250 241 RWKW with Advance Headers, Twin 2.5" Exhaust, G&D CAI, Walbro Pump, Crow Cam, Custom Tune |
05-02-2009, 09:47 AM | #12 | ||
I did them on the rotor, just because I've only just started playing around with my car and I didnt know if the caliper was just a simple bolt off, bolt on process so i just left it alone.
05-02-2009, 10:29 AM | #13 | ||
Looks good. If you can get it to look like that without removing the caliper, theres really not much point in taking them off. The finnish wont be THAT much better, and it saves the hastle of removing them.
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
05-02-2009, 10:32 AM | #14 | ||
SKID IT
should get some black paint and do all the inner gaurds etc
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba Where the boost junkies hang out -Forced Ford Forums |
05-02-2009, 08:07 PM | #15 | ||
Next upgraded Mk1 Leopard
I did mine when I changed the rotors (see below). I would paint the rotor center as well like Whoosha suggested. Looks great.
UK Whilst I had them off I painted the brakes (Light blue). The front was pretty straight forward and I used ronwest rear replacement guide for the back. (see this thread) http://www.fordforums.com.au/vbport...warticle&id=319 I like the colour, pity I can't see how they look when the car is moving. So pics... Out with the old in with the new.. and the rears.. UK
05-02-2009, 09:55 PM | #16 | |||
Neglecting the P250
05-02-2009, 10:54 PM | #17 | ||
HAHA well at least you gave it a go, learnt how to do it etc....
At least you had safety in mind with the hand brake haha |
06-02-2009, 05:59 AM | #18 | |||
Blown 5L coming
hhhmmmmm me thinks its time for me to do this to mine now LOL. looks good pmpdau but deffinitly a darker blue like UK's would have been better.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
06-02-2009, 11:17 AM | #19 | |||
06-02-2009, 11:25 AM | #20 | ||
Yeah I did look for a darker blue, but unfortunately the colour range for actual High Temp Caliper paint is limited, by limited this was the only blue autobarn and super cheap had....i probably couldve hunted around but all in all im happy with the result, they did darken a fair bit after drying.
06-02-2009, 06:10 PM | #21 | |||
Neglecting the P250
06-02-2009, 06:16 PM | #22 | ||
Hmmmmm im not going to bother about my front calipers, the stock AU I version are a poor excuse for a caliper, ill just wait till i replace the brakes next and throw some PBRs and and spray them then.
